gaskets
- 123vucku
gaskets
16 Jan 2015 17:24
Sort of a newbie question but do valve cover gaskets for a 1976 kz900. ..do they go down with the flat side to the head surface or does the rounded part of the gasket go down .
Re: gaskets
16 Jan 2015 18:40
I'd put the "flat" side down. These are stamp formed. That's why it looks that way. Might make it easier to reuse later. Put a dab of sealant under and where the cam caps meet the head.
- 123vucku
- PLUMMEN
Re: gaskets
17 Jan 2015 10:54
Do you have a picture of the gasket youre using? :huh:
- zukdave
Re: gaskets
17 Jan 2015 18:08swest wrote: Put a dab of sealant under and where the cam caps meet the head.
Yup that'll help the cam's stay in place and tear shit up when you start it.
Why the hell do people call the 1/2 moon cam cover end plug's cam cap's ?.
They ain't the same thing and can be misleading and cause someone to fuck their shit up.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
The following user(s) said Thank You: PLUMMEN, daveo, !Seymore
- daveo
Re: gaskets
17 Jan 2015 19:00zukdave wrote:swest wrote: Put a dab of sealant under and where the cam caps meet the head.
:laugh: :laugh: :laugh: ... :whistle:
1982 KZ1100-A2/1170 sleeper 😀
Re: gaskets
17 Jan 2015 19:32zukdave wrote:swest wrote: Put a dab of sealant under and where the cam caps meet the head.
OK cam plugs. I also call what YOU are talking about CAM TOWERS. Have been for 40 years.
Re: gaskets
17 Jan 2015 19:34
BTW, he was talking about a gasket not some thing stupid. :sick:
- zukdave
Re: gaskets
17 Jan 2015 20:42
Sorry I just think people should use the correct term for the part they are referring to
when trying to help those less informed about engine's.
Kinda like my bike has a motor and an engine.
The ELECTRIC. MOTOR start's it the COMBUSTION ENGINE make's go down the road.
Cam tower is the cast part of the head that the cam rest in.
Cam cap's are the part that hold's the cam in the cam tower's.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Re: gaskets
17 Jan 2015 20:54
I declare apostrophe abuse.
Re: gaskets
17 Jan 2015 21:15 - 17 Jan 2015 21:17
Piston pin AKA wrist pin, cam towers/cam journals etc.etc,etc.
That which we call a rose, by any other name would smell as BAD.
Shakespeare hacked. :evil:
Last edit: 17 Jan 2015 21:17 by SWest. Reason: ad
- 123vucku
