1985 GPZ 550 transmission locked
  • Mark Ohio 1976
  • Mark  Ohio 1976's Avatar Topic Author
Re: Re:1985 GPZ 550 transmission locked
19 Nov 2014 19:07
#654166
I pulled the left cover off tonight. The two shafts turn together for about 1/4 of a revolution. This makes me think it's in two gears at once... What do you guys think?
  • Mark Ohio 1976
25 Nov 2014 06:24
#654582
I pulled the sump cover on the bottom. I see a shift fork laying in the bottom of the transmission. Time to pull the engine
  • Tyrell Corp
  • Tyrell Corp's Avatar
25 Nov 2014 12:45
#654612
Ok is it the complete selector fork, or just part of it? There are/was three forks in there.
Gearbox problems are very rare on the 550's.
In he UK these motors are two a penny, so don't feel the need to spend a packet on it.
The gear ratios are all the same on the 400/500/550's , including the ZR550 and maybe even the GPZ600 ninjas. ..so if your shafts are damaged -very likely, then have plenty of choice.
If you are cross referencing part numbers, the later zx and GT550 shaft drive have a revised circlip arrangement. If yuo get that far let me know. In the uk we had a zx550 A5 - the last of the GPz550's.
Remember what I said about loosening the clutch centre nut and primary shaft nut before you take the
motor out. You can split the cases without disturbing the crank and top end.
  • Mark Ohio 1976
25 Nov 2014 12:53
#654615
I got it out and split.
The gears look great. It seems that someone took the rod out that has the two forks on it one fork fell into the crankcase and is a little bent.
Attachment ImageUploadedByTapatalk1416948639.913574.jpg not found
Attachment ImageUploadedByTapatalk1416948661.529124.jpg not found
  • loudhvx
  • loudhvx's Avatar
25 Nov 2014 14:01
#654629
The only time I've seen anything like that was on bikes that were towed and/or trailered. If a bike is trailered on a non-suspended, lightweight trailer, this can sometimes happen. (I know a guy with a CBR that just had this happen this year). It's best to remove the chain.
Somehow his gear selector bounced the trans into gear, then all of the jostling on a cross country haul wreaked havoc in the trans. He had to replace all of the shifter forks. If the chain was removed, it would never have been damaged. This is not a bike being towed with the wheel on the ground, it was on an ultra-light trailer that bounced a lot.
  • Mark Ohio 1976
26 Nov 2014 16:02
#654705
Attachment ImageUploadedByTapatalk1417046312.210063.jpg not found
I got the cases back together. Everything looks good!
  • Tyrell Corp
26 Nov 2014 16:38
#654713
were the dogs and gears undamaged?
did you buy it as a non-runner or did that happen by itself?
unusual problem, hopefully sorted now.
  • Mark Ohio 1976
26 Nov 2014 16:59
#654720
The gears and dogs looked great. I am not sure why someone messed with the shift rod... It shifts fine now, hoping it works fine under load.
The engine interior looked very clean too.
