1976 1015 with APE 410 cams hp and tuning info
  • SeattleKZ
  • SeattleKZ's Avatar Topic Author
Re: 1976 1015 with APE 410 cams hp and tuning info
02 Nov 2014 08:26
#652607
LarryC wrote:
SeattleKZ wrote: The stock 1977 Kz1000 carbs were 26mm and worked fine.
I understand the CR's have better mid range adjustments and if I am unable to tune the bike to my liking with the 26mm's on the Dyno then I will consider getting them.
I think "but have no actual data to prove" the 28mm carbs would work better but still have mid range problems so if I do end up getting different carbs to solve mid range tuning I'll most likely get the CR29's.
Two important things.....Ok...possibly3 :)
1 - Jetting from 25 years ago doesn't apply to todays pump gas. Everthing wants more fuel than it used to require. That means bigger jets... You just proved that.
2 - Fuel level is very important to have properly set before any jetting is done.
3 - CRS29's will put a big smile on your face once they are dialed in. If you think it runs good now....wait till you ride it with a rack of properly jetted CRs..
I believe you might be right but until the Dyno tells me the stock 26mm carbs have no adjustment possible to make the bike run right I will not spend that kind of money. My Dyno costs so far have been $20. In the end I might spend $150 on Dyno runs with the stock carbs.
  • LarryC
  • LarryC's Avatar
02 Nov 2014 08:45
#652614
SeattleKZ wrote:
LarryC wrote:
SeattleKZ wrote: Why would it be a waste of time Floivanus? I am really close to having a perfect A/F mix with that stock carbs. Have you run the same bike with both 26mm carbs and 28mm carbs on a dyno and found a huge difference in power? My buddy put some CR29's on a bike and gained 5hp. The bike specs were 82hp at the crank and that was probably higher because motor companies always put down a number that's in a perfect world. I currently have 92hp at the rear wheel. I'd say that's a pretty decent number.
Dyno Jet dyno.... right?
Sorry, what's the question?
What brand of dyno is it being tested on?
Larry C.
  • PLUMMEN
  • PLUMMEN's Avatar
02 Nov 2014 09:07
#652618
floivanus wrote: If anything try it out with a set of 79-80 vm28s and see if theres a real difference, smoothbores and a 1015 sounds like a waste imho.
A set of 29 smooth bores would wake it up,but for the price of used ones Id just buy a new set of 29 crs for it.
  • LarryC
  • LarryC's Avatar
02 Nov 2014 12:07
#652637
Absolutely... you never know what you get with used carbs and the price...whew.. wow. For a little more money you get new..
Larry C.
  • zukdave
  • zukdave's Avatar
02 Nov 2014 17:03
#652664
Their's people out there that would give enough
for my smooth bore's to damn near buy some CR29's.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • LarryC
  • LarryC's Avatar
03 Nov 2014 01:31
#652712
zukdave wrote: Their's people out there that would give enough
Well guys used to get pissed at me when I'd tell them dumping $400+ in a set of BS34 Mikunis was a mistake...but they did it anyway and likely still are. Go figure ;)
Larry C.
  • SeattleKZ
03 Nov 2014 05:47
#652727
Haha, I here ya both. There's no way I'm pouring money into vintage carbs when I can buy a set of CR29's and be done with it. After my next Dyno trip I will post back with full results.
And yes Larry it is a Dyno Jet brand Dyno
