2nd gear slip?
- SeattleKZ
2nd gear slip?
11 Oct 2014 07:54
Somewhere around 5-6k rpms my 2nd gear slips. It is only 2nd, all the other gears work fine. I put in a new clutch hoping that would help but did not. It just slips for split second and then engages and runs the rest of the way just fine. Anybody else ever have this problem? Know what it might be?
This is in regards to a 1976 KZ900
- turboking
Re: 2nd gear slip?
11 Oct 2014 08:00
most likely dogs on 2nd gear rounded off :dry: or possible shift fork. :huh: ........rounded dogs force gears apart...... it's a common issue of missed shift of cramming the tranny back in gear :S .....
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
- SeattleKZ
Re: 2nd gear slip?
11 Oct 2014 08:01
Is that something that can be done without splitting the cases?
- turboking
Re: 2nd gear slip?
11 Oct 2014 08:02
cases have to be split for tranny repair .....new gear or have old gears undercut :ohmy:
1985 GS 1150E
1983 GS 1100E
1985 GS 1150E
1983 GS 1100E
- SeattleKZ
- etbike3135
Re: 2nd gear slip?
11 Oct 2014 08:04 - 11 Oct 2014 08:05
Most likely the transmission gears are wore. This is most common in second gear. Easy to see when you get them out. There are not a lot out there with perfect gears after all these years, they all have some degree of wear. You can take the oil pan off and its not easy but you can get a look at the gears. You'll be looking on the output shaft for the 2 gears closest to your sprocket. They should look like these but they get rounded on both sides of the gears.
1973 Kawasaki Z1
18 years in dragbikes
Last edit: 11 Oct 2014 08:05 by etbike3135.
- turboking
Re: 2nd gear slip?
11 Oct 2014 08:06
you can do shift forks without splitting cases.....but it sounds more likely you have bad dog/gears................. :S
1985 GS 1150E
1983 GS 1100E
1985 GS 1150E
1983 GS 1100E
- SeattleKZ
Re: 2nd gear slip?
11 Oct 2014 08:06
ok, next time I do an oil change I'll pull the pan and have a look
- SeattleKZ
- turboking
Re: 2nd gear slip?
11 Oct 2014 08:16 - 11 Oct 2014 08:16
you have to remove the trans cover behind sprocket and have the oil pan off.......... i'd just drop the pan first myself......as it's more likely you have a 2nd gear issue
1985 GS 1150E
1983 GS 1100E
1985 GS 1150E
1983 GS 1100E
Last edit: 11 Oct 2014 08:16 by turboking.
- etbike3135
Re: 2nd gear slip?
11 Oct 2014 08:17
Same way, with the pan off. Most times the forks are worn from trying the keep worn gears in place. So most likely the gears go first then the forks.
1973 Kawasaki Z1
- SeattleKZ
