Cam timing woes. Worst weekend in a long time.
- peter1958
- Banned
Re: Cam timing woes. Worst weekend in a long time.
21 Jul 2014 13:03
god I sound like nads when I drink
www.kzzone.com/
The following user(s) said Thank You: Tomolu5
- madmatt1
21 Jul 2014 13:54 - 21 Jul 2014 13:56They changed the spec in the mid/late 70's for the 1000's and the factory manual recommends applying that retrospectively to 900's too as they are all basically the same engine.
I have five zeds ranging from std to turbo'd and run all close to the upper .15mm if possible (shim range permitting) and once they dip below around .9mm I pull the heads and do what's needed to re-gain clearance but that takes many many 1000's of miles.
They will run happily at those higher .20mm race specs , they will run a little noisier but I find a loud pipe cures that
Well this is good to know- thanks. I think most of my shims are around the 245 area, and I only have a few thinner than that... Might be time to build up the shim collection! Might be time to get a second job too! :laugh:
1977 KZ1000 LTD
1979 KZ1000 LTD
1978 KZ1000A
1979 KZ1000 LTD
1978 KZ1000A
Last edit: 21 Jul 2014 13:56 by madmatt1.
- peter1958
- Banned
21 Jul 2014 14:11
I will trade shims as long as you pay postage. I have a few
www.kzzone.com/
- madmatt1
21 Jul 2014 14:12god I sound like nads when I drink
Whaddya doing drinking during the day on a Monday, anyways?
Yeah, I'm going to be much more careful about those shims from now on. Speaking of drinking, little occurences like this are the reason I DON'T drink when I work on the bike :laugh: Easy enough to F things up under normal circumstances!
1977 KZ1000 LTD
1979 KZ1000 LTD
1978 KZ1000A
1979 KZ1000 LTD
1978 KZ1000A
- peter1958
- Banned
21 Jul 2014 14:13
east coast I start at 5 am
www.kzzone.com/
- madmatt1
21 Jul 2014 14:18
I appreciate the offer! However, I first need to buy a good range of them to even have ones to trade. I only own a few spare shims from 230-250. That's all that this bike has in it... a pretty close group!
1977 KZ1000 LTD
1979 KZ1000 LTD
1978 KZ1000A
1979 KZ1000 LTD
1978 KZ1000A
- peter1958
- Banned
21 Jul 2014 14:20
just let me know what you need and send 1 for each i send plus shipping. I have 80 or more
www.kzzone.com/
- madmatt1
21 Jul 2014 14:23
Right on- Thanks!
1977 KZ1000 LTD
1979 KZ1000 LTD
1978 KZ1000A
1979 KZ1000 LTD
1978 KZ1000A
- 80B4
21 Jul 2014 17:57
It sounds like madmatt needs to buy the tools needed to accuratly measure and then set his cam timing. A degree wheel, piston stop, dial indicator & mount and a pair of adjustable sprockets and you will be good to go. There are lots on-line how to's to help you understand it. Good luck.
1980B4 1000
1978 Z1R
1978 B3 750
1978 Z1R
1978 B3 750
- madmatt1
21 Jul 2014 18:20 - 21 Jul 2014 18:28
I just got in from the garage. Reset the cams, and this time I installed the OEM idler & blocks. The outcome was exactly the same.
80B4- I've been thinking about getting those tools for a while, I think you are correct- it's time to do it. I'm not going to lie, the usage of the dial indicator, piston stop, and degree wheel may as well be nuclear physics to me right now.. but I'd like to learn!
So is this situation pretty normal, and something that many people overlook, OR is it pretty obvious that my cam chain is just quite stretched? All of my real-life experience setting up cams has been on engines with...one cam :laugh:
Is it possible I have just been driving it like this & didn't know it? (Like maybe when I assembled the engine, I got them to line up on assembly, and called it good before setting chain tension and rotating the crank.) Is this small of a timing difference really enough for most people to notice when the engine is running? Because it seemed to run very well to me.
1977 KZ1000 LTD
1979 KZ1000 LTD
1978 KZ1000A
1979 KZ1000 LTD
1978 KZ1000A
Last edit: 21 Jul 2014 18:28 by madmatt1.
- 80B4
21 Jul 2014 20:39 - 22 Jul 2014 05:46
Cam degreeing only sounds hard untill you do it one time. Ebay has all of the tools, they even have kits with all the tools and a how-to dvd. If I can do it, you can do it too!
Use the Liska parts, they are very good, make sure all of the other timing parts are good. Ask around about lobe center numbers for stock cams in a stock motor. Larry C. may help with that.
The only way to know if things are right is to do it yourself. So, good luck and get to work!
1980B4 1000
1978 Z1R
1978 B3 750
1978 Z1R
1978 B3 750
Last edit: 22 Jul 2014 05:46 by 80B4.
- bountyhunter
21 Jul 2014 23:18 - 21 Jul 2014 23:19Seems like that's the only conclusion left in the realm of probability at this point......madmatt1 wrote: I
Last edit: 21 Jul 2014 23:19 by bountyhunter.
