timing advancer
- Grumpy Ole Artist
- Eschew Obfuscation!
timing advancer
08 Jul 2014 16:57
Need some more learned eyes...first one of these I have seen...I have a miss at higher rpms...noticed some fairly substantial deviations. Pic one shows difference between raised lower area and section that pokes through points plate.(off center from one another) Pic 2 shows wear from overhead.( note non-concentric top of "tube") bike has 28k on it...is this wear normal/acceptable?
1978 KZ650 B2
Former rides...1976 CB360T, 1985 Shadow 700, 1985 GPZ750Turbo
- kaw-a-holic
Re: timing advancer
08 Jul 2014 17:12
The wear looks okay but I am far from an expert! More of a novice. All I can tell you is I would dismantle it, clean it and lube it. I believe you can buy replacement pads but that would not effect top end timing. If I remember right, anything after 4-5K in the RPM range is fully advanced. I personally took mine apart and polished the parts clean and smooth. Then I coated the crap out of everything with heavy duty silicone spray. There are other suggested lubes but the silicone spray dries and does not attract dirt like oil does. reassemble and make sure everything moves freely.
BE CAREFUL NOT TO BREAK THE SPRINGS WHEN REMOVING THEM THEY DO NOT SELL REPLACEMENTS. Although I have read here that Chevy distributor springs are the same size and spring rate.
Hope this helps
Hope this helps
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
- Grumpy Ole Artist
Re: timing advancer
08 Jul 2014 17:29
It definitely looks a little cruddy! I am concerned about the eccentric nature of the surface the points' blocks ride on, relative to centerline....would think it has some pulsing effect ? ill certainly clean & lube as advised if conncensus deems part worthy of further use. Thanx for the feedback, as usual!
1978 KZ650 B2
- 4TheKZ1000
Re: timing advancer
08 Jul 2014 18:12
buy a Dyna 2000 unit
you can take the advancer a throw it in the trash can.......
- Grumpy Ole Artist
Re: timing advancer
08 Jul 2014 18:15
Ouch :blink: anybody want to buy a brand new set of black dyna coils?
1978 KZ650 B2
- 4TheKZ1000
Re: timing advancer
08 Jul 2014 18:21
Don't get to excited, you better check the price of a Dyna 2000 first.........its shocking.
- Grumpy Ole Artist
Re: timing advancer
08 Jul 2014 18:29
Not excitement, believe me! More sarcasm...seriously, the coils are a month or so old...kinda vested now...more to my OP...does the part NEED to go in the trash can? Thanx again!
1978 KZ650 B2
- 4TheKZ1000
Re: timing advancer
08 Jul 2014 18:47
nope, clean it up, oil it like kaw-a-holic said, should be ok.
- Grumpy Ole Artist
Re: timing advancer
08 Jul 2014 18:51
Will do! Thanx!
1978 KZ650 B2
Re: timing advancer
08 Jul 2014 19:38
Keep in mind that you are looking at a little cam so it should not be concentric with the shaft. That does look like a good bit of wear. Obviously maintenance was neglected. I would take it apart, properly clean and lube it, lube the felt pad that keeps the cam surface lubed (and should have been lubed as part of normal maintenance), install new points & condenser and give it a try. Ed
- koolaid_kid
Re: timing advancer
08 Jul 2014 20:03
And if you decide to go electronic, get a Dyna S. The black coils will work fine with it, and it is a lot cheaper than the Dyna 2000, which is really for drag bikes.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
Re: timing advancer
08 Jul 2014 20:14 - 08 Jul 2014 20:16
I concur with koolaid_kid.
Could consider a new Dyna-S ignition system, which should be okay with the same coils designed for a points ignition.
For example, if the coils are 3Ω or 4Ω, they should be okay with Dyna-S.
Lots of us kept using the original coils for a long time after replacing the points ignition with Dyna-S.
Dyna-S has its own rotor and permanently replaces the points system.
Last edit: 08 Jul 2014 20:16 by Patton.
