pistons and rings
  • PLUMMEN
  • PLUMMEN's Avatar
Re: pistons and rings
06 Jul 2014 20:12
#639087
DLP wrote: Almost forgot but the manual says range from .08-.18 mm is range but what if you are right on limit should it be changed or left alone, if I did this right this was my numbers cyl. 1= intake .10/exh .10 - cyl. 2=intake .10/exh . ? - cyl. 3 intake .13/exh .08 - cyl. 4= intake .10/ exh .10 , the question mark on on the one is because I couldn't even get my smallest gauge in to check which was a .04mm
Can you spin the bucket with lobe pointed away from it? ;)
  • DLP
  • DLP's Avatar Topic Author
08 Jul 2014 15:42
#639332
Took me a bit to get back out there n check but yes I can spin the bucket
  • PLUMMEN
  • PLUMMEN's Avatar
08 Jul 2014 16:29
#639336
You have some cleaeance then and the valve is not being held open causing compression issues at least.
  • DLP
10 Jul 2014 12:08
#639600
I am a bit confused on changing the shims, do I have to remove the cam chain tensioner or just take the tension off it, the manual I have says to remove it but I think its referring to if and when trying to remove the whole head.
  • DLP
10 Jul 2014 12:10
#639602
And just to clarify it is a 1982 kz750 h3 with automatic tensioner
  • PLUMMEN
  • PLUMMEN's Avatar
10 Jul 2014 12:38 - 10 Jul 2014 12:40
#639610
If it uses shims like a 650 theyre under the bucket.
If theyre shim under bucket youll have to remove tensioner and cams then remove the buckets to change the shims.
If it uses shims on top like the 900/1000 series bikes you can make a toolto push bucket down out of a bent screwdriver, then you just need a metal wedge to hold bucket down while you change the shim.
*if it uses the 900/1000 style shims leave the tensioner alone.
Last edit: 10 Jul 2014 12:40 by PLUMMEN.
10 Jul 2014 13:55 - 10 Jul 2014 13:56
#639630
PLUMMEN wrote: If it uses shims like a 650 they're under the bucket.
If they're shim under bucket you'll have to remove tensioner and cams then remove the buckets to change the shims.
That's what they are - shim under bucket. Before attempting to remove the shims read the appropriate sections of the manual very carefully and ask any questions you may have before starting. Also, before you start take close-up photos of the cam sprocket and crankshaft orientation so you know how they should look when you re-install each cam. Do one cam at a time. Be sure to have an appropriate torque wrench (INCH pounds) for re-assembly and do not apply more torque than the Kawasaki Service Manual specifies. Ed
Attachment 00005_2014-07-10.jpg not found
Last edit: 10 Jul 2014 13:56 by 650ed.
The following user(s) said Thank You: PLUMMEN
