are these stupid clips called
- Cynjut
Re: are these stupid clips called
21 May 2014 08:40
While cotter pins and hitch pins perform the same basic function, there are differences. A hitch pin is a reusable device while a cotter pins is (generally) not. Cotter pins are bent to secure and are usually used where positive control of the pin is needed (like inside a wheel assembly). For more information see:
www.globalspec.com/learnmore/building_co...tter_pins_wire_clips
Cotter pins, and hitch pins are both members of the "wire clip" family and the terms are often used interchangeably. The website goes into detail one when one or the other is appropriate.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
21 May 2014 08:50 - 21 May 2014 08:54
I wouldn't call it a cotter pin. In common usage in the USA, a cotter pin is a single use pin.
From wikipedia: the pin in question is an R-clip.... aka, R-pin, R-key, hairpin cotter pin, hairpin cotter, bridge pin, hitch pin, or spring cotter pin. I'm sticking w hitch pin.
Last edit: 21 May 2014 08:54 by martin_csr.
- PLUMMEN
22 May 2014 03:28
hitch pin
- barney
22 May 2014 04:58
Ha ha .Im glad someone else replied with this first. I always called them Jesus clips too, but Hitch pin is the ticket I think
z1kzonly wrote:Ditto on the "Jesus clips" 40 years so far!slayer61 wrote: I've always called them "Jesus clips"
As in "Jesus! where did it go?" when it flies off!
Or Thanks! J, for holding them fasteners together.
Looks like seat pin clips Ram.
- PLUMMEN
22 May 2014 19:26Jesus/elvis is usually the guy you swear that you see when the nut/bolt it was holding disappears at 100mph! :woohoo:barney wrote: Ha ha .Im glad someone else replied with this first. I always called them Jesus clips too, but Hitch pin is the ticket I think
