update on new exhaust.. cracked mounting screw
- jgraham232
Re: update on new exhaust.. cracked mounting screw
14 May 2014 11:52
There is still some thread sticking out. Enough where I can gently use grips. I have already begun the perpetrating spray. I figure I'll do it to the bolts twice a day until the new ones arrive then see if they will loosen.
Strangest thing, just took it for a ride came back parked it went to go back on it to go to work and my throttle was sooooooo stiff I could barely change gears, there is also some what looks like oil very very slowly coming from where the clutch lever on the engine goes into the engine. I may drain like 2 cups of oil and see if that help, I may have filled it a bit too much when I changed the oil yesterday. Over compensated for the filter. I'm still new and learning, that's why I bought an ok bike instead of one in great shape though. It's a learning money pit lol.
Strap up, Sit down, Ride Smooth.....
1983 kawasaki kz550 spectre shaft
- jgraham232
14 May 2014 11:53
I should also note that the first run it shifted like magic. And ran beautifully. It seems to be loosening slowly but Idk what to do.
14 May 2014 11:55
Did you check your motor oil level using the site glass with the bike on the center stand? Ed
- jgraham232
14 May 2014 11:56
I unfortunately don't have a center stand but had my gf hold it level. I had it full then ran it for 5 mins so that some would soak into the new filter. It now sits about 3/4 full. Is that too much? Too little?
14 May 2014 12:01
It should be fine as long as it is between the 2 lines next to the site glass. Even if it is near the top line that shouldn't be a problem. Ed
- jgraham232
14 May 2014 12:13
So I was just letting it run for a bit to see if things settled and after a trip around the block and letting it idle for 15 minutes, it died without any interference from anything. I should also mention I'm not sure if my battery's fully charged, I haven't been tendering it as I don't have one. Maybe that could be causing the problem? I'm gonna bring it to auto zone and have then test/charge it overnight.
Ugh. Motorcycles are so fun.. but so frustrating.
14 May 2014 12:18
Be careful about letting the bike run without moving or a large fan blowing on the motor. These are air cooled engines and they will overheat if left idling too long. Ed
- gengomerpyle
14 May 2014 12:21
it can be replaced. if it was me i would put some penetrating spray on it and let it sit over night. then the next day try to unscrew it with a pair of vise grips, but go easy with it
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
1971 Honda CB750K
- jgraham232
14 May 2014 12:30
Ahhhh. That I didn't not even think about. Ugh I'm so used to my car. Wish I could have just gotten a car. Damn insurance companies. At least I was lucky enough to have bought en a bike with a following like the X series. Thank you all for the help. I hope to someday return the favor to someone that needs help as I'll be riding for a long time
