Valve stem seals won´t fit?
- PetterA
-83 Z1000 Eddie Lawson Replica
-71 H1 Mach III
- sbc1320
- Thank you received: 38
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
- 4TheKZ1000
- Visitor
I had a bike come into a friends shop that had different valve stem sizes.
Exhaust valves 7mm and Intake valves 8mm, on the same valve guide outer diameter?????
I can remember this clearly, as I was running parts for him and made like 3 trips before we got the right seals.
- PetterA
4TheKZ1000 wrote: Does it not fit snug on the valve stem or the valve guide or both?
Exhaust valve 7mm and Intake valve 8mm, on the same valve guide outer diameter?????
The seals does not fit on the valve seat, but it fits on the stem. The valve stem sizes are the same diameter, but one side of the valve seats seem to be smaller.
-71 H1 Mach III
- 4TheKZ1000
- Visitor
Almost impossible to check the diameter of that guide in the bore? my caliper wants to hit side of bore before getting to guide.
I would guess all valve seals look alike and nothing sticks out. All guides look similar?
I would guess you could get different seal diameters, but what is the guide O.D. ?
Should be a 8mm stem. (My bad 7mm)
- PetterA
4TheKZ1000 wrote: Sounds like someone was in there messing around.
I suspected something like that...
I have to check the measures and see what may fit, but the stems are 8mm on both sides, but the guides are different, a bit smaller on one side and thats why the seals won't fit. The old seals had som kind of metal housing.
-71 H1 Mach III
- LarryC
When you say it's loose on the guide, do you mean you can pluck it right off with tweezers? Or do you mean it stays on but spins easily around the guide?
I use nothing but APE guides in everything. Never a problem with those.
BTW if that's your old 500, I'd love to ride it. It's been a loooooooong time since I rode one. That was my second bike.
Larry C.
- turboking
- Thank you received: 106
:blink: Z1/kz stems are 7 m.m.
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
- PetterA
Sorry, the stems are 7mm so the head is KZ1000.
Will give the head to the local Kawasaki dealer who will help me get correct seals!
-71 H1 Mach III
- bountyhunter
- Thank you received: 337
No. I rebuilt my engine at 75k miles and the guides measured like new. They don't wear unless something is fitted wrong.PetterA wrote: Yep, the guides are some kind of aftermarket so the usual seals are too big - is it usual to change the guides during porting or any other king of modification to the engine?
- wireman
- Thank you received: 299
Yes they do wear depending on the material.PetterA wrote: Yep, the guides are some kind of aftermarket so the usual seals are too big - is it usual to change the guides during porting or any other king of modification to the engine?
They are often removed during a serious porting job to make things easier, then new ones are reinstalled.
- LarryC
One reason to replace the guides is because of the cam choice. Stock guides are too tall for cams over .420 lift. You can start running into issues with the keepers hitting the valve seals. The APE guides are shorter on top where the seal mounts.
Are you certain that the guides haven't been rubbed by the inner valve springs and worn down? I've seen that happen when the inner springs break into pieces. Look it over really well.
Larry C.
