Oil Passage Blocked ? Or IS IT !!!!!
  • 4TheKZ1000
  • Topic Author
  • Visitor
19 Jan 2014 08:00 - 19 Jan 2014 12:22 #619152 by 4TheKZ1000
Oil Passage Blocked ? Or IS IT !!!!! was created by 4TheKZ1000
During inspection, I noticed this. The oil hole on upper case base is covered by the base gasket.
The gasket imprinted or sank into the oil passage galley and could have been restricting oil flow.
Couldn't really see any top end damage. The cam bearings were within spec at .032 to .038 and the cams measured out ok with no loss of lobe material, shims and buckets were ok.
There must have been adequate oil or just dumb luck.
Should the gasket be put on as it is sold? or should the gasket be cut to open flow?
My thought is it should not be trimmed or the gasket would come that way?
Thanks, Spencer
Attachment IMG_37851600x1067.jpg not found
Attachment IMG_37961600x1067.jpg not found
Attachment IMG_3798-Copy1600x854.jpg not found
Attachment T2eC16FHJHoFGlmuyhizBR0OFIk3eQ60_57.jpg not found
Last edit: 19 Jan 2014 12:22 by 4TheKZ1000.
  • 4TheKZ1000
  • Topic Author
  • Visitor
19 Jan 2014 13:17 #619182 by 4TheKZ1000
Replied by 4TheKZ1000 on topic Oil Passage Blocked ? Or IS IT !!!!!
Anyone wish to comment ?
Thanks
19 Jan 2014 14:04 #619189 by sbc1320
Replied by sbc1320 on topic Oil Passage Blocked ? Or IS IT !!!!!
I don't see any reason why it can't be cut back if you wanted. It's not sealing against anything so it's just along for the ride is all.
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
  • 4TheKZ1000
  • Topic Author
  • Visitor
19 Jan 2014 14:24 #619191 by 4TheKZ1000
Ya, just wondering why Kawasaki did it that way?
I just wonder if cut, will it cause a leak on the back side?
The way it sunk into galley really bothers me though.
19 Jan 2014 15:25 #619198 by Powerstroke_fan
Replied by Powerstroke_fan on topic Oil Passage Blocked ? Or IS IT !!!!!
Ive never had any problem with them. But i wondered why kawasaki did that also
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
  • Bozo
  • Ride it like u stole it
19 Jan 2014 15:38 - 19 Jan 2014 15:42 #619201 by Bozo
Replied by Bozo on topic Oil Passage Blocked ? Or IS IT !!!!!
NORMALLY Its ok, the oil comes out of the small hole and then gets pushed under the gasket and up the stud to the head, you can cut the gasket but there is no need
BBBUTTT looking at your gasket it should not be pushed down blocking the oil hole so good thing you caught it in time.
The first item to suffer would be your camshaft bearings, if they are ok (no scuffing on the bearing surface) everything else should be ok.
Just looking on the edges of your gasket it looks like your gasket is wrinkled??? what compound are you using to cause that?? normally the gasket does not drop into the cavity. I suspect you need to look at the compound that "melted" your gasket.
Last edit: 19 Jan 2014 15:42 by Bozo.
19 Jan 2014 15:44 #619203 by 80B4
Replied by 80B4 on topic Oil Passage Blocked ? Or IS IT !!!!!
Not blocked, every big kz I've had appart is that way. It is another good reason to dry block it.
1980B4 1000
1978 Z1R
1978 B3 750
  • 4TheKZ1000
  • Topic Author
  • Visitor
19 Jan 2014 15:50 - 19 Jan 2014 15:55 #619205 by 4TheKZ1000
Thanks BOZO, but it was a Wiseco gasket provided with my 1105 kit.
I put it on dry with no chemicals and don't use any additives in my oil.
I use Rotella 15w-40.
When I pulled the cylinder, the gasket stayed with the top case and it had no wrinkles.....and took 2 to 3 hours to get off......... :blink:
Really don't know what to think, but thanks for responding.
Last edit: 19 Jan 2014 15:55 by 4TheKZ1000.
  • 4TheKZ1000
  • Topic Author
  • Visitor
19 Jan 2014 15:52 #619206 by 4TheKZ1000
80B4 wrote: Not blocked, every big kz I've had appart is that way. It is another good reason to dry block it.
___________________________________________________________________
80B4, have you seen the gasket droop into the galley that way before?
Thanks
19 Jan 2014 16:26 #619213 by 80B4
Not every one, but yes. The OEM gaskets are better then aftermarket.
1980B4 1000
1978 Z1R
1978 B3 750
  • Bozo
19 Jan 2014 16:53 #619216 by Bozo
although I can count the number of times I had the Z1r apart on one hand, I have not seen a base gasket that bad, the gasket was a bit sloppy / sagged but never to that amount, I know wiseco supply good stuff but I can't help looking at the wrinkly parts and wonder that something is not right.
As stated before I did have a known brand base gasket which just started falling apart, so I had to remove the barrel/ head extra to fit a new one (I used a genuine gasket this time - dry) and it appears ok (I won't know till it goes apart next time?).
Lately I have been concerned about the quality of gaskets supplied because my friend also had his gaskets wrinkle up and appear to swell, is there something in the new oils?, I don't know maybe someone out there might have an answer.
  • 4TheKZ1000
  • Topic Author
  • Visitor
19 Jan 2014 17:15 #619218 by 4TheKZ1000
I will send these pictures to Wiseco and ask them what the deal is.....
Will report back with what they say.
