How to minimize air flow with air pods?
- e.dishong2
I have air pods on my bike now, 1983 KZ750n2 spectre. Im trying to tune my carb after rebuilding it. I know when using air pods you need to get your carbs jetted, but damn I know SOMEONE has found a way around this. I read about cutting down some soda cans and putting them inside the pods to restrict airflow. This sounds good, but it takes some playing to get the air flow just right. Well sense my carbs are not adjusted right, I cant tell if its too much air coming in, or I need to adjusted my air/fuel screws. I would just order a filter for the factory airbox. But im leaving town in a couple days and I want to get this bike running before I leave so I can sleep and enjoy my vacation!This will not be permanent, just temporary.
- sbc1320
- Thank you received: 38
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
- JR
- Thank you received: 448
With pods your best solution is to experiment with larger jets sizes or look for a jet kit from Dynojet.
If you are trying to reduce the airflow through the pods then I have read about people wrapping duct tape a portion of the pod surface but I am thinking this or any "soda can" method would be a bit of a crap shoot. Pretty crude and unlikely to get your bike running as good as it should.
Good luck
- catseye
That being said, I have seen people get their bike to run right by covering pods with duct tape, but that's a pretty half-baked way to go.
1982 KZ750LTD
1976 BMW R90/6
1982 Honda CBX
- guitargeek
- Thank you received: 50
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- e.dishong2
This is my airbox, this is all I have. minus the rubber boots that attatch to each carb
Attachment T2eC16ZwsE9suwyRubBSM159uBN60_3.jpg not found
- bountyhunter
- Thank you received: 337
They also fired the arrow then drew the target to match where it landed...... which is to say the length and taper of the carb needles was cut so that it matched the airflow characteristics and gave proper fuel mix across the full RPM range.sbc1320 wrote: I don't think it is only the restriction as it is also the path of the air flow, turbulence, etc.. Don't get me wrong mine has pods on it also, but those original engineers who designed these hotrods knew what they were doing.
- JR
You might get it started with the pods or with duct tape around a portion of the pods.
The airbox in your picture is missing the airbox cap as you say. This is part # 11012 in the diagram (kawasaki.com owner info, parts diagrams etc etc) . The air filter does not come with the cap. If you had the cap you would just remove it, drop in the filter and replace it. According to kawasak.com the cap is no longer available
Also according to kawasaki.com the same cap was used on the following models so you may be able to pick one up on ebay or from a recycler
- Forrest
- The Mad Duck
- Thank you received: 180
- e.dishong2
- Thank you received: 2829
- guitargeek
I think you're probably looking at the case vent.e.dishong2 wrote: main vacuum line coming from the crank case
You should definitely buy a manual...
