I can't tell if it is running lean or rich
  • Salder69
  • Salder69's Avatar Topic Author
Re: I can't tell if it is running lean or rich
10 Dec 2013 19:55
#615252
AtLarge wrote:
Salder69 wrote: I have the mikuni 38 carbs.
83 belt drive had BS34 stock
Main jet 115
Pilot jet 45
Starter jet 70
If you still have the stock air box ditch the pods and go back. Search the twins forum for "Moog mod" for a way to connect the carbs to the box easily.
kz400.createforumhosting.com/
If you can find entire stock airbox assembly for a kawasaki kz750 (twin) LTD K1 under $50 I'll buy it.
Until then, the pods will suffice. Soon I'll get some K&N pods, until then I'm probably like everyone else - Forever wanting more - always strapped for cash.
@ Z1Driver - It's pretty icy here in OKC. As soon as I get a day with clear, dry roads, that is above 50 degrees I'm gonna do that. I only have 42 miles on my new (working) dash, I'm dying to have fun with my bike, but its like a frozen wasteland where I am.
THanks everyone for the help.
  • Stazi
  • Stazi's Avatar
11 Dec 2013 06:35 - 11 Dec 2013 06:35
#615266
What's the spacing between the carbs? Could you use one of these instead:
www.knfilters.com/search/product.aspx?prod=ru-2850
www.amazon.com/RU-2850-Universal-Rubber-...8-1&keywords=RU-2850
The flange size fits the BS34's I'm gon to run two of these on my KZ1000 which has 4 of the BS34's
82 KZ1000-K2 LTD
Last edit: 11 Dec 2013 06:35 by Stazi.
  • Z1Driver
  • Z1Driver's Avatar
  • love the smell of triple smoke
11 Dec 2013 12:33
#615300
Yeah, it's pretty cold where I am too. My bikes are sleeping until spring. Not looking towards a valve check on the C14 with shims under buckets.
Blue 1975 Z1B
Red 2009 Concours 14
12 Dec 2013 05:41 - 12 Dec 2013 05:45
#615340
Z1Driver wrote: . . . Not looking towards a valve check on the C14 with shims under buckets.
"Checking" is the quick and easy part.
Just insert thickness gauge between cam and bucket with cam lobe pointing away from the bucket.
And the clearances may be found within specs to rule out tight valves as being an issue.
If clearance adjustment is found to be necessary, the shims must of course then be accessed.
Good Fortune! :)
Last edit: 12 Dec 2013 05:45 by Patton.
  • AtLarge
  • AtLarge's Avatar
11 Feb 2014 10:37
#621907
Main jet 115
Pilot jet 45
Starter jet 70
It's your lucky day. Complete and under $50.
1973 Honda CL70-K3
1975 Kawasaki 350 F9-C
1983 Kawasaki KZ750-K1
1994 BMW K1100RS
2008 Suzuki GSX1300-BKK8 #1120
