KZ650 turbo monster
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: KZ650 turbo monster
23 Nov 2013 17:01
#613939
zukdave wrote: First thing I think he should do is go hang out on GPz750 turbo.
but to be honest I think he over his head and doesn't have a clue.
Way over.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
23 Nov 2013 17:58 - 23 Nov 2013 18:03
#613945
You got the bike sounding great les. Did you ever mess around with a distrabution blocks?
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Last edit: 23 Nov 2013 18:03 by Powerstroke_fan.
  • Brewdog
  • Brewdog's Avatar Topic Author
25 Nov 2013 08:06
#614052
Im just trying to see all the options. and i did some looking around as you said the FI system would work alot better than carbs.i have no clue on how i should go about this, I am in over my head which is why i came to this fourm to ask how should i go about this. I am learning right now and just exploring all the options... now I can have the machine shop bore out the cyl to 750 or i could go and try and find a 750 cyl and the pistons i need. ill look for a FI system from a 750 turbo and figure out a manifold. ill do some more looking and get my head on straight and figure out exactly what needs to happen
  • Stazi
  • Stazi's Avatar
25 Nov 2013 08:19
#614054
If you're intent on doing this, you should really think about getting an intake manifold made and then go for a draw-through set up with a single carb. It will be WAAAAAAAAYYYY easier then trying to go with a blow through.
82 KZ1000-K2 LTD
  • Brewdog
25 Nov 2013 08:32
#614055
I like carbs, but after looking all weekend i have to agree with T_dub FI is the way to go. I had assumed it would be hell to run FI. I was wrong. I was being stuborn and didnt want to break away from carbs thinking it was the way to go. The single carb would be easier than the 4, but the FI would work very nice, and i think the shop at my tech school has one setup laying around so before i do anything im going to go check that out.
  • zukdave
  • zukdave's Avatar
25 Nov 2013 16:54
#614081
Brewdog wrote: i think the shop at my tech school
Biggest problem I see right there.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
