Oil sight cloudy looking?
- KZQ
- Administrator
Re: Oil sight cloudy looking?
07 Nov 2013 20:41Beaner242 wrote:I ride it everyday that it's not raining. And far enough to get up to temp. I'm not quit following what you trying to say hereKZCSI wrote: The answer is simple this bike is not ridden enough and when it is ridden it's put up before the whole engine and transmission can come up to temp.
What are the products of combustion? Water vapor and carbon dioxide. Our engines share the case with the transmission
Bill
A milky site glass is a very common especially with synthetic oils when water vapor is frothed into oil and the bike doesn't get up to temp.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- bountyhunter
07 Nov 2013 21:15+1 That's what water looks like. gasoline will mix into it and thin it, but it won't make white foam. Only water.4TheKZ1000 wrote: Water + Oil will turn to a milky brownish white color......
- bountyhunter
07 Nov 2013 21:16Sometimes a problem with the crank case vent can allow condensation to form in the crank case.Beaner242 wrote:Yes I know. That's what I was saying. It's not possible unless someone is messing with it where I park. My curiosity is now getting the better of me. I'm going out to drain the oil.4TheKZ1000 wrote: Water + Oil will turn to a milky brownish white color......blew a 2.8 ltr up in my chev S-10 when a head gasket slowly let go. Antifreeze got into oil and slowly destroyed engine
The oil was a milky brownish white.......
- bountyhunter
07 Nov 2013 21:19 - 07 Nov 2013 21:20What is the crank case breather hose connected to?Beaner242 wrote: My nephew just mentioned riding in the rain. Which I did get caught in Monday night. For about a mile. Wasn't actually raing at the time but the roads were wet. How would it get into the case from rain though? Have Uni pods no air box.
Last edit: 07 Nov 2013 21:20 by bountyhunter.
- Beaner242
07 Nov 2013 21:42bountyhunter wrote:What is the crank case breather hose connected to?Beaner242 wrote: My nephew just mentioned riding in the rain. Which I did get caught in Monday night. For about a mile. Wasn't actually raing at the time but the roads were wet. How would it get into the case from rain though? Have Uni pods no air box.
The breather tube off the case just has a small breather filter clamped to it. No hose running any where. I going to say it was from the rain the other night. It never occurred to me that it would make it into the oil. I was pretty wet by the time I hit the garage so water hitting my air filters and the crank case filter, must have been enough to get in there I guess.
1982 KZ1000K LTD Chopper
- bountyhunter
07 Nov 2013 23:43Yeah, I would have guessed the crank case filter. I can't picture much water getting past the rings while it's running, but maybe it can? When gasoline gets into the oil, it's from flooding down into the cylinders and then draining down past the rings when it's not running.Beaner242 wrote:bountyhunter wrote:What is the crank case breather hose connected to?Beaner242 wrote: My nephew just mentioned riding in the rain. Which I did get caught in Monday night. For about a mile. Wasn't actually raing at the time but the roads were wet. How would it get into the case from rain though? Have Uni pods no air box.
- turboking
08 Nov 2013 06:15
+1 .........
definitely water........some how moisture is getting into the crank case vent
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
- turboking
08 Nov 2013 06:23
if it's the chopped bike in your avatar......... NO rear fender or inner fender :S IMO, water is thrown forward into the case vent from the rear wheel.....crank vent filter or not :pinch:
1985 GS 1150E
1983 GS 1100E
1985 GS 1150E
1983 GS 1100E
- Beaner242
08 Nov 2013 07:10turboking wrote: if it's the chopped bike in your avatar......... NO rear fender or inner fender :S IMO, water is thrown forward into the case vent from the rear wheel.....crank vent filter or not :pinch:
yes that is my thought to. just cant decide on what fender i want, and dont ever plan on riding in the rain, i just happen to get caught out in it the other night.
- Stazi
08 Nov 2013 07:18
Put the crank case vent on a longer hose and mount it up high under the seat somewhere to protect it from the rain etc.
82 KZ1000-K2 LTD
08 Nov 2013 07:33Stazi wrote: Put the crank case vent on a longer hose and mount it up high under the seat somewhere to protect it from the rain etc.
Or route the longer hose to exit underneath the bike.
And toss the filter, which imo is useless -- like who other than the EPA folks care about whether air is being filtered as it exits the crankcase (which is the purpose of the vent).
- Beaner242
08 Nov 2013 09:30
yes ive thought of this also. honestly the the filter is just on there for looks, its like a mini K&N lol
