An early goodbye?
- saucedogg
1980 KZ440-B
Sacramento, CA
- Beaner242
- Thank you received: 16
1982 KZ1000K LTD Chopper
- bountyhunter
- Thank you received: 337
That phrase just means the repair cost exceeds the resale value. But if you like the bike, you may want to spend the $ to fix it. I rebuilt the motor on my '79 KZ-750 and spent more than the resale value, but I wanted to keep the bike running.saucedogg wrote: As I was riding home today, my 1980 kz440-B1 started making a weird clacking noise (like a deep-pitched baseball card in bike spokes) and subsequently died on the freeway. At first it wouldn't start back up, but after waiting a few minutes, it would start, make the same noise, and die again if I had to downshift. I walked it to a local shop and was told a bushing from a crankshaft connecting rod probably gave out and that actually opening it up and finding the broken part would be more trouble than the bike is worth. I don't know what to do. The shop-man told me that replacing the entire motor is the only practicable way to salvage my beloved bike that I've only had for a few months. Do I have to say goodbye so soon?
That clacking noise may be a con rod bearing failed that is binding up the bearing. Could maybe be the internal drive chain. No way to know until it gets looked into. Getting a running used engine is always an option.
- bemoore
- Thank you received: 4
If you want to keep this bike, I would dig into the engine as much as you can. If you can't find and/or fix the problem, I'd find another engine. I haven't priced 440 engines, but I wouldn't think that they were too expensive.
77 KZ650C1 w/Kerker 4-1
- Thank you received: 2829
www.themotorcyclepartsoutlet.com/cgi-bin/store/index.cgi
Attachment 00004_2013-10-26.jpg not found
- Philip Meaney
On the other hand, you might find a whole motor (or parts bike) at a wrecker or perhaps Craigs list for cheap. Swapping the motor out is a couple hours work and isn't a difficult task. Depending on your experience level, this might be a good path to developing a bit more knowledge and confidence before tackling more complicated tasks.
Once your old motor is out, you can tear it down and decide if you want tackle a rebuild at your leisure.
Just a thought.....
80 750 H1
85 750 Turbo
84 GPz 750
- sbc1320
- Thank you received: 38
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
- Old Man Rock
- Thank you received: 225
As for if she's worth going in, all depends on you.
Some of us enjoy the challenge of taking a 30 year old beat to death girl and fixing her up. Splitting her open, going into her depths, examining WTF etc.... and of course spending ridiculous amount of $$$ regardless... We're a sick bunch that way. :laugh:
Case in point, will I truly ever get my $$$ back from my build, nope not going to happen but I didn't build her for the return investment. It's my hobby/passion, ok screw it, my OBSESSION..... :whistle:
So if you're one of us sick &twisted, that enjoy then by all means get after it (winter project).
If you don't have the tools, space, time what ever then obtain a another project build cheap for the engine./parts
Or, take the hit and get yourself a KZ900/1000 and sell this one for a parts bike/project....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- steell
sbc1320 wrote: Crank would most likely need to be turned, rods resized along with new rod bolts if it is the rod bearings.
No. Cranks are "ground" on a crank grinder, not turned, and undersized bearings are not available for any KZ, as far as I'm aware.
The three sizes listed in the manual only vary by around 0.0015" or so, just to correct production tolerances.
If you can find a real, experienced mechanic, then he/she can tell you what's wrong by listening to it.
I'll give you a hint, if it knocks under acceleration , it's not a rod bushing.
- Z1Driver
- love the smell of triple smoke
- Thank you received: 55
$150
503-309-4180
Blue 1975 Z1B
Red 2009 Concours 14
- saucedogg
1980 KZ440-B
Sacramento, CA
- koolaid_kid
- Thank you received: 99
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
