900 Overbore Advice
- KansasKZ
Re: 900 Overbore Advice
07 Oct 2013 20:11
This thread is right up my alley. I'm looking to bore my 1015 as well. OMR, if you could send me some contact info for Pit Stop or just post on here that would be very helpful. Thank you.
1978 KZ1000 A2A
- racer54
07 Oct 2013 21:22
Not sure of the years of the shaft drives but I think they were only 79-80. If that is right, then it would have the MK11 motor basically. That means the best crank and trans. With the shaft drive trans all you have to do is change out the output shaft for one from a regular trans and you have the MK11 trans...best KZ trans. The crank is the strongest KZ crank but heavier but it also makes for a smoother motor. It would also take a 1075 kit no problem at all...even with the cases. Other then that, OMR is right on...makes a very good case. Or sell that shaft drive motors parts to help finance your build...
- Old Man Rock
08 Oct 2013 07:36
Check your PM for URL Address....
E-mail them your desires/questions, very responsive and good service in my dealings with them.
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
