Take a look at my lapped valve seat please.
- pbmax
Re: Take a look at my lapped valve seat please.
01 Oct 2013 14:26zukdave wrote: Put the valve and spring back in and spray carb cleaner in the port
if any run's pass'd the valve it ain'f seating.
I filled exhaust port with brake cleaner and let it sit for a bit and there were no leaks.
- car5car
- Banned
02 Oct 2013 10:37 - 02 Oct 2013 12:13
Lapped surface looks too narrow to me, but I am a car engine guy. Pitting is too big. You need more lapping or machine shop.
Is that a crack at 3.30 on first picture? Take a magnifying glass and high resolution picture. I increased your picture 400% and could see 2 cracks next to each other, I think.
Lap as long as needed, you'll check clearance later.
I could only see crack on picture of Jeep head.
I almost never bring heads to machine shop, I lap by drill.
Attachment valveseat.jpg not found
96 Yamaha Royal Star
82 Yamaha Virago 920
Last edit: 02 Oct 2013 12:13 by car5car.
- sbc1320
02 Oct 2013 12:11Motor Head wrote: Post up some pictures of the Valves, showing where the contact patch is and the width. You want that as close to Center as possible, and within the spec for the width. For cheap Bluing Compound, you can mark the valve face with a Black Sharpie and then see where the contact area is.
You will more than likely need to re-shim, as you were probably already close to the min on clearance.
You read my mind as I was going to say color them with a sharpie or felt tip marker and then lap them again and you will see what's going on.
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
