Cam cap bolt hole problem.
  • Garn
  • Garn's Avatar
Re: Cam cap bolt hole problem.
21 Sep 2013 06:52
#607233
Almous71, In my earlier post I mentioned "Bigserts", just to be sure you know what they are.... They are made by the same company that make "Timesert", however, they go in a larger hole, hence, can usually take care of off-centre errors, if there is enough meat where you are re-threading. Lots of engineering shops are not familiar with these!
RegardZ
1 x 73 Z1 (Jaffa), 74 Z1A, 76 Z900-A4
1 x 73 Yamaha TX500 & 98 fzx250 Zeal
Sydney Australia
  • almous71
  • almous71's Avatar Topic Author
  • Newbman
21 Sep 2013 11:55
#607247
Thanks Garn, I did see your mention of bigserts, and I'm still looking for a shop that uses them. I'm concerned that there's not enough meat left to cut into though:
Attachment image.jpg not found
I know it can be welded and machined, but I suspect that'll be more than I can afford at the moment.
1981 KZ550-A2
Va.Beach, VA
  • pbmax
  • pbmax's Avatar
23 Sep 2013 14:19
#607447
Seeing that picture, wouldn't the gasket surface need to be re-surfaced as well?
  • MDawnz1
  • MDawnz1's Avatar
24 Sep 2013 02:23
#607532
Sorry to say but that looks like it's weld it up time.
Mike
1974 Z1a, still 903
  • almous71
  • Newbman
25 Sep 2013 00:50
#607689
Or possibly a new used head.
On another note, dose anyone know if the marks on these journals and part of my intake camshaft indicate normal wear or more serious damage?
Attachment image_2013-09-24.jpg not found
Attachment image_2013-09-24-2.jpg not found
Attachment image_2013-09-24-3.jpg not found
1981 KZ550-A2
Va.Beach, VA
