Calculating Cylinder Pressure Reading
  • Motor Head
  • Motor Head's Avatar
Re: Calculating Cylinder Pressure Reading
12 Sep 2013 09:30
#606163
I would also check the valve clearances if you haven't.
  • MDawnz1
  • MDawnz1's Avatar
13 Sep 2013 02:08
#606262
Do you know what?
You are ALL right.
BUT.
All that matters is are you within 10% of what the book says?
ALOT of people who went to school ALOT longer then me came up with that #
Then run a leakdown test, still within 10% cyl.to cyl?
You will be good to go for a while.
Mike
1974 Z1a, still 903
