- Thank you received: 4
Engine case studs
- geerbangr
30 Aug 2013 17:11 #603953
by geerbangr
1978 KZ 1000
I go by Jason
Engine case studs was created by geerbangr
How come every time I see bare engine cases the block studs are still installed ? Same with the block and exhaust studs. Are they non removable ? What happens if one breaks or the threads strip ? They don't ever stretch and need replaced ?
1978 KZ 1000
I go by Jason
- MDawnz1
- Thank you received: 27
30 Aug 2013 17:24 #603957
by MDawnz1
1974 Z1a, still 903
Replied by MDawnz1 on topic Engine case studs
The reason they are in there is because they are supposed to UNTIL you want them out.
The threads in the cases and heads go into aluminum and wear out if you mess with them to often.
Yes they do come out,
Yes they can be replaced with stock or better studs,
Yes they do break (CAN BE A MAJOR BUMMER)
That help ?
Mike
That help ?
Mike
1974 Z1a, still 903
- geerbangr
30 Aug 2013 17:42 #603961
by geerbangr
1978 KZ 1000
I go by Jason
Replied by geerbangr on topic Engine case studs
Oh yeah that helps. Majority of my mechanics are involving cars so when i see certain things with these bikes it makes me scratch me head.
So is it wise with a total rebuild to "upgrade" the studs ?
1978 KZ 1000
I go by Jason
- Powerstroke_fan
- Thank you received: 83
30 Aug 2013 17:44 #603963
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic Engine case studs
I would, but if its a stock motor, its probably not neccesary.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- geerbangr
30 Aug 2013 17:56 #603967
by geerbangr
1978 KZ 1000
I go by Jason
Well I'm seriously considering building a 1428 and turning this old kz of mine into a street fighter. It'll take me a couple years to build do to the cost of building it but I already have a bike for a cruiser and would like to have a ground pounder to ride when the wife isn't with me. :woohoo:
Just trying to gather all the info I can so when I get ready to do the engine I know what I'm building.
1978 KZ 1000
I go by Jason
- bluezbike
- Thank you received: 104
30 Aug 2013 20:52 #604000
by bluezbike
79 KZ 1000 LTD
Replied by bluezbike on topic Engine case studs
If you are pumping the motor up to 1428, I would definitely install the Heavy Duty Studs as well as HD inner case bolts and camshaft cap plate, all these are sold by APE. One consideration when using the HD studs is they are bigger diameter that stock so the outer oil passageways leading up to the head become restricted. There are a few ways (and opinions)on how to overcome this...one is to dry block the motor (see Zed 1015's thread on how to) and the other is to drill out the oil passageway in the cylinder block. I have done neither of these so I don't know which one is best but I will have to choose in the coming months for the motor I will be building.
79 KZ 1000 LTD
- Dr. Gamma
- Thank you received: 680
30 Aug 2013 22:02 #604022
by Dr. Gamma
1986 RG500G 2 stroke terror.
Replied by Dr. Gamma on topic Engine case studs
Does MTC Engineering still make their H/D "Golden" cylinder studs for the KZ's??
Same dimensions as the stock studs, just made out of better metal.
Never had or showed any signs of oil starvation in the cylinder head with those studs.
Nicely made, all rolled threads!!! Installed height was always right on too!!
- daveo
- Thank you received: 655
30 Aug 2013 22:07 #604024
by daveo
1982 KZ1100-A2
Replied by daveo on topic Engine case studs
bluezbike said: One consideration when using the HD studs is they are bigger diameter that stock so the outer oil passageways leading up to the head become restricted.
I installed APE cylinder studs in my stock KZ1100 engine, and haven't experienced any problems with oil restriction. The studs are thicker in diameter, but not significant enough to cause noticeable issues on my engine, except for having to modify the head gaskets to fit around the center-most pairs of studs.
I had two instances where head-gasket oil leaks developed at the front outside stud locations, which I attribute to stretching of the OEM studs over the course of time and a couple head replacements.
Not an issue any longer, thanks to the APE studs and nuts.
1982 KZ1100-A2
- geerbangr
05 Sep 2013 00:43 #604935
by geerbangr
1978 KZ 1000
I go by Jason
So..........stud removal for upgrade, how to properly remove them ? Heat the case then remove studs ? How does the broken stud removal work ?
1978 KZ 1000
I go by Jason
- bluezbike
05 Sep 2013 00:54 #604945
by bluezbike
79 KZ 1000 LTD
Apparently Snap-on has a really good tool for this that works like an automotive oil filter removal tool but I remove them (I have done this on three cases) with a small pipe wrench gripping the stud near the base which does wreck them up a bit but if you are replacing with heavy duty who cares?....no need to heat up the cases. Some of them come out pretty easily, no rhyme or reason. I would imagine the usual broken bolt removal process should work with drilling a hole and an extractor although I have never done one.
79 KZ 1000 LTD
- eddiem
- KZR FLAG RELAY CARRIER #63
- Thank you received: 34
05 Sep 2013 01:46 #604948
by eddiem
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
Replied by eddiem on topic Engine case studs
two nuts jammed together then put a wrench on the bottom nut and unscrew it out
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
- Powerstroke_fan
05 Sep 2013 07:40 #604967
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Or if theyre junk take a some vise grips and use them to break the studs loose.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
