Where have all the second gears gone?
  • floivanus
  • floivanus's Avatar Topic Author
Re: Where have all the second gears gone?
22 Aug 2013 21:10
#602705
Bought trans off ebay, pictures were wrong, its a shaft trans and guess what, 2nd gear dogs are worn at a near 40degree angle.
Garbage again.
Getting tired of this crap, about to give up on this crap and go to hondas, they dont have the power to break gears
Past; 78 kz1000, 83 kz550
Andrew
  • bluezbike
  • bluezbike's Avatar
22 Aug 2013 22:25
#602718
Boy...you must be fed up to mention the "H" word. I have a complete trans for you if you want to give it one more go. :)
79 KZ 1000 LTD
  • 74ullc
  • 74ullc's Avatar
23 Aug 2013 02:35
#602743
Trying to learn from this thread so please excuse my ignorance.... :blush:
Are we talking about the three tabs (dogs) on the top left gear in the photo under HEAVY DUTY TRANSMISSION GEARS near bottom of page here....
kzzone.com/trans.html
So the dogs on the second gear get rounded off so they slip out of the slots and the transmission jumps out of gear? Once it starts doing this it just gets worse and worse each time it slips out until you are left with little nubs that will no longer hold at all? Is it the input or output gear that goes bad? Plus on KZ trans when 2nd goes 5th goes with it?
And here is another page showing what undercut is....
www.aperaceparts.com/transmissions.html
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
23 Aug 2013 08:16
#602753
If you need a good place to get a good trans, i know a couple people to try. I would try brain (kz1006). If not maybe try giving pearson racing a call. He might be a little more expensive, but he will be sure to get you a good one. He can also back cut them for you.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
23 Aug 2013 08:34
#602754
  • zed1015
  • zed1015's Avatar
23 Aug 2013 11:10
#602770
Patton wrote: www.pitstopperformance.com/contact_us
Good Fortune! :)
Yep! you can get a full undercut cluster for £200 from Joe or have your own worn dogs undercut or buy a billet second gear from ape or drop in a MK2/LTD box(slightly beefier gears and extra dogs) etc, etc. the list goes on.
