Time for a new clutch?
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
Re: Time for a new clutch?
30 May 2013 08:09
#589885
i got mine from z1
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
30 May 2013 09:00
#589893
Kitten Tooth wrote: Where would you guys recommend getting an OEM clutch pack? im not rich so take that into account. :D
The friction plates and springs are still “Active” Kawasaki parts, so any dealer can get them for you. Ronayers.com lists the genuine Kawasaki friction plates at $7.77 each and springs at $3.38 each. Ed
Attachment 00000_2013-05-30.jpg not found
  • Kitten Tooth
  • Kitten Tooth's Avatar Topic Author
30 May 2013 17:38
#589965
should i replace the steel plates too?
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
  • Kitten Tooth
30 May 2013 18:07
#589967
Oh man, this Ronayers place is kickass. im going to place an order today with them. getting more then just a clutch. i need some others stuff too haha
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
30 May 2013 18:22
#589970
Kitten Tooth wrote: should i replace the steel plates too?
You may want to check them to see if they're warped, but I would expect them to be ok. Ed
  • DoubleDub
  • DoubleDub's Avatar
30 May 2013 18:36
#589972
Don't replace anything until you've checked the wear and warpage. Most likely you need to move to JASO MA oil and possibly replace the clutch springs (cheap). These clutches are built very well and last for many many miles (mine is still good after 50k with a new set of springs). If you have a spare head lying around you can even rob the inner valve springs rather than buying new ones. I have used these on my bikes and like them for street riding: www.z1enterprises.com/ItemDetails.aspx?i...f1000+Z1&item=LACSK7
  • kzz1king
  • kzz1king's Avatar
30 May 2013 18:56
#589974
I use the inner springs as well, works for me.
Wayne
Home built KZ1000 turbo setup
  • WABBMW
  • WABBMW's Avatar
  • Let The Good Times Roll !
30 May 2013 19:07
#589975
Whatever you do, be sure to adjust the set screw on the left side cover. Remove the small plate with 2 large phillips screws; loosen the locking nut several turns while holding the inner screw from turning; then turn the screw clockwise until it turns easily; then turn counter-clockwise until you feel a slight resistance; the manual says to rotate the screw 1/4 turn clockwise, hold it in that position, and tighten the lock nut. (I prefer 1/2 turn).
This adjustment is setting a small amount of clearance for the pushrod that goes from the cam operated actuator (left side under the cover, and operated by the clutch cable), over to the pressure plate which releases the clutch. With wear, the clearance can become zero or less, and the clutch cannot fully engage. This adjustment is independent of the clutch lever clearance.
Sometimes the screw can get corroded in the cover, making it difficult to tell what is going on. While you have things apart, clean and lubricate the threads on the inner screw and lock nut. Good luck.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
  • DoubleDub
30 May 2013 20:21
#589986
