1979 kawasaki KZ750 LTD
  • kledda970
  • kledda970's Avatar Topic Author
24 Apr 2013 03:42
#583802
I have a kawasaki kz750 ltd 2stroke. when i bought it the guy told me that he changed the wiring so tht the electric start doesn't work meaning so it can hav more torque, but the kick for sure works. everytime i ride it, the spark plugs seem to wear out within 2 hours of riding, and after those 2hours, the bike will start to die out every half a mile. i hav no idea what is wrong with it. someone please help me. :'( its my first bike.
  • baldy110
  • baldy110's Avatar
Re: 1979 kawasaki KZ750 LTD
24 Apr 2013 11:55 - 24 Apr 2013 12:49
#583819
Since Kawasaki did not make a 2 stroke LTD I will assume your talking about the 4 cylinder 4 stroke LTD. Removing the electric starter will not give the engine more power. What do you mean the spark plugs wear out, do you mean they foul out. I hope because you mentioned it is a 2 stroke you are not adding oil with your gas. You havent given us much to work with here.
Last edit: 24 Apr 2013 12:49 by baldy110.
The following user(s) said Thank You: kledda970
  • martin_csr
  • martin_csr's Avatar
24 Apr 2013 12:52 - 28 Apr 2013 10:09
#583820
A 79 should be a 750-B Twin. Do not add 2-cycle oil to the fuel.
The service manual will have charging system & ignition system checks.
Check the battery to make sure it is good.
PS: don't believe anything the po said - people forget, don't know, or flat out lie & make up stuff.
Last edit: 28 Apr 2013 10:09 by martin_csr.
  • kledda970
24 Apr 2013 13:20
#583827
its the 750 B twin. the spark plug turns all black. near the hook and threads
24 Apr 2013 13:57
#583831
kledda970 wrote: ...bike will start to die out every half a mile....
If runs about 1/2 mile, dies, then starts and runs another 1/2 mile, dies, etc., might be fuel starvation resulting from a blocked fuel tank vent.
To test for this condition, may try running with the fuel tank cap ajar (not closed completely down), which assures venting.
Good Fortune! :)
24 Apr 2013 14:18
#583833
kledda970 wrote: I have a kawasaki kz750 ltd 2stroke. when i bought it the guy told me that he changed the wiring so tht the electric start doesn't work meaning so it can hav more torque, but the kick for sure works. everytime i ride it, the spark plugs seem to wear out within 2 hours of riding, and after those 2hours, the bike will start to die out every half a mile. i hav no idea what is wrong with it. someone please help me. :'( its my first bike.
If you were told it is a 2-stroke and are using pre-mix 2-stroke fuel or adding oil to the fuel it is no surprise the plugs are fouling. Kawasaki never sold a 2 cylinder 750CC 2-stroke, any 2-stroke LTD, or any 1979 750cc 2-stroke. Your bike is a 4-stroke and uses normal gasoline with no oil mixed in with it. Ed
  • kledda970
24 Apr 2013 14:41
#583838
I am not adding any oil to the gas. jus regular gasoline. im sorry if im wrong. it probably is a 4 stroke. but im sure its a 2 cylinder. 2 spark plugs, 2-2 intake
  • kledda970
24 Apr 2013 14:46
#583839
[attachment:1]C:\fakepath\DSC00823.JPG[/attachment]
right now, i actually have to get another new pair of spark plugs. because after the 2 hours or riding, then half miles of starting and dying. it will soon enough not start at all, until i get new spark plugs, which i have to do right now
  • TexasKZ
  • TexasKZ's Avatar
24 Apr 2013 20:28
#583868
Badly fouled spark plugs (really black) are generally cause by one or more of the following
-- enrichner (choke) being left on while riding.
-- the fuel mixture is too rich. Common causes are improperly adjusted carburetors, malfunctioning float valves, clogged air filter.
-- insufficient electrical current at the spark plugs. Common causes are weak battery, corroded connections in the wiring, bad coils, rotten secondary wires.
-- excessive oil consumption. Often caused by bad valve seals or worn piston rings.
Since you mentioned that the previous owner messed with the wiring, that would be at the top of my suspect list. A weak battery would be a close second. With an old bike, there may be a combination of causes. A genuine factory shop manual, some quality tools, a great deal of patience, a wad of money, and the generous help of folks around here will get the bike working smoothly again.
  • zukdave
  • zukdave's Avatar
24 Apr 2013 22:15
#583873
Are you having to charge the battery each time it foul's the plug ?
I'check that it charging at 13 volt's or it will not keep up with the light's.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • kledda970
25 Apr 2013 05:00
#583923
i just bought a new battery. i don't have to charge it at all. mainly is the spark plugs and the whole big jus dying out on me within a few hours of riding
  • kledda970
25 Apr 2013 20:32
#584025
no, i don't have to keep charging the battery after the fouls
