- Thank you received: 1
wired right???
- steveo_4192003
- 77kz650b-1
29 Jun 2006 21:19 #58188
by steveo_4192003
1977 kz650b-1, 4-2exhaust systetm, pod filters ,jetted 112 main, 17.5 pilot
wired right??? was created by steveo_4192003
ok, my bike died on me today, and my battery is dead!
i jumped it and it started but when i took off the jumper-cables it died.
so, should i be-able to run the bike after its started with-out the battery hooked up? or should it die and not run?
i took off the jumper and it sputtered and backfired really loud! if i kept it connected it ran fine.
i rode for at least 30 min then hit the gas station!
when i went to take off it died and got flooded thats why battery is dead
how long can you ride on just battery power? few minutes? hours?
i had about 1.5 hours total run time on battery w/out recharging and always bright lights and started right up
any help will be greatful!!
Post edited by: steell, at: 2006/06/30 00:48
- steell
29 Jun 2006 21:52 #58195
by steell
Replied by steell on topic wired right???
Ok, I moved it and removed the "Please move" from your subject
If the battery was dead, it takes a while to recharge it, a few minutes won't do it.
Sounds like you may have charging system problems, there is a really good charging system troubleshooting guide in the filebase under the "KZ Information" tab at the top of the page.
- steveo_4192003
- 77kz650b-1
29 Jun 2006 21:56 #58196
by steveo_4192003
Replied by steveo_4192003 on topic wired right???
thanks, and ill try not to let that happen agian!! lol!!
- loudhvx
- Thank you received: 1616
30 Jun 2006 01:12 #58208
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic wired right???
the 77 650 needs a battery to work correctly. Later models of the KZ 650 might be able to run without the battery.
1981 KZ550 D1 gpz.
Other links.
