# 4 sparking wierd...
  • donthaveakawman
  • donthaveakawman's Avatar
Re: # 4 sparking wierd...
12 Apr 2013 16:19
#582004
she don't idle well through 25 mph zones and the b8es is factory.
  • donthaveakawman
12 Apr 2013 16:20
#582005
maybe some electrical grease under the spark plug caps for insulation.
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
12 Apr 2013 18:12
#582023
donthaveakawman wrote: she don't idle well through 25 mph zones and the b8es is factory.
That sounds more like a carb problem, not a spark plug issue.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
  • donthaveakawman
14 Apr 2013 21:16
#582325
An 850hp drag-race motor that spins to 9,000 rpm will require much colder plugs capable of quickly transferring all that additional heat away from the center electrode.
Read more: www.carcraft.com/howto/116_0703_spark_pl...l.html#ixzz2QUB6T0kK
basically you went the wrong way with the heat range and so did I.
  • andyvr4
  • andyvr4's Avatar Topic Author
23 Apr 2013 20:22
#583759
Thanks everyone it ended up being coils bought accel 140403 msd 8mm wires and all is good..
1983 kz750 Ltd 4 cyl.
Andy
