How to get the mech. advance off
  • Matteson
  • Matteson's Avatar Topic Author
10 Apr 2013 00:55
#581538
So the bolt is broke off in the top left. I tried extracting it with everything on. But I'm just spinning my wheels. So to take the whole housing off is what I need to do. But the advance is a little hard getting off. Do I just spin the 13mm bolt counterclockwise that is on the 17mm bolt while holding the 17mm bolt steady? I do not want to cause anymore damage than what I am trying to get fixed. That little 13mm bolt doesn't want to budge.
KZ 900-a4
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
Re: How to get the mech. advance off
10 Apr 2013 08:13
#581559
Yes you can just lossen the 13mm bolt and that will allow you to remove the advancer.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
  • Matteson
10 Apr 2013 09:19
#581571
counterclockwise?
KZ 900-a4
10 Apr 2013 10:35
#581585
It may have corroded threads; try soaking it with Kroil for a day or two.
  • martin_csr
  • martin_csr's Avatar
10 Apr 2013 11:00
#581589
Yes, counterclockwise. If you don't have any Kroil, Liquid Wrench penetrating lubricant is a good one & cheap. Apply the penetrant & let it soak for a while. You could wipe off the excess, warm up the engine, then apply some more & let it soak. Also, if need be, use a wood block & mallet to tap the bolt - vibration helps to loosen stuck bolts. Apply some more penetrant.
  • Matteson
10 Apr 2013 11:31
#581599
Got it off. Just needed a little help from the cheater bar. SO now there is the oil seal. I couldn't find any definite answers in the manual . But I hope the can of worms I am opening doesn't cost me more time and money. I just need the rh engine cover out of the way to tap a new thread . Any important info before I goand try prying off the rh cover?
KZ 900-a4
  • Matteson
10 Apr 2013 12:37
#581608
stupid worries. sorry. i got it off just fine. now the hunt on for 7mm helicoil.
KZ 900-a4
  • baldy110
  • baldy110's Avatar
10 Apr 2013 12:47
#581612
You are going to need the 6x1 mm helicoil.
  • Matteson
10 Apr 2013 13:17
#581622
No. I used a .25 to get the trash out. I thought of just jb welding .25 helicoil in there since it's non load bearing. The hole is at .288 now. Any ideas that are better than mine? Really i thought the next size is an m7.
KZ 900-a4
10 Apr 2013 16:52
#581666
Matteson wrote: Got it off. Just needed a little help from the cheater bar. SO now there is the oil seal. I couldn't find any definite answers in the manual . But I hope the can of worms I am opening doesn't cost me more time and money. I just need the rh engine cover out of the way to tap a new thread . Any important info before I goand try prying off the rh cover?
Which oil seal?
  • Matteson
10 Apr 2013 21:38
#581710
with the advance off there is a rubber oil seal right there. When I got the bolts removed I gently pried on the housing and everything came off smoothly.
KZ 900-a4
  • Matteson
10 Apr 2013 21:53
#581713
the rubber piece I was talking about. I was hoping it wouldn't become damaged from taking the housing off the crank case was all. When I am doing something for the first time I get worried that the lesson learned will be a valuable one :unsure:
KZ 900-a4
