83 KZ750 Spectre - Possible interchangable head
- SpectreCafe
Re: 83 KZ750 Spectre - Possible interchangable head
18 Jun 2013 18:29
Forgot to send an update on this, but I ended up buying a head from a 82 KZ750 std, bolted it up and it started up! Seemed to run fine.
While I had it apart, I also found 2 cracked pistons though, so seems that the bolt that came loose did more damage than I originally found. Didn't want to keep digging to end up finding more, So I ended up selling the bike as is (running but the disclaimer that it had cracked pistons). Got my money back and now to the next project.
1983 KZ750 Spectre
- jenningsjesse
07 Jul 2017 17:29
Are the 82 N1 Spectres the same block and head as the 83? Any diferrences in thos two year 750 Spectres? Im also looking for a head. I was told the 82 N1 was all GPZ. Big cams, big valves, and higher compression pistons, in turn, cylinder block is different than a standard kz. Mine is blacked out carbs and cylinder block just like all the straight up gpzs I've seen.
- jenningsjesse
06 Sep 2017 16:10
Steell, do you still have the 83-85 gpz/spectre head for sale?
