1978 kz 1000 A2
  • baldy110
  • baldy110's Avatar
Re: 1978 kz 1000 A2
26 Mar 2013 21:07
#578983
How long did you let it idle in your garage? These are air cooled engines.
  • LarryC
  • LarryC's Avatar
Re: 1978 kz 1000 A2
26 Mar 2013 22:53 - 26 Mar 2013 22:58
#579019
jared55b69 wrote: I have had my kz1000 for 5 months now and it has been running well. It started smoking a little on deceleration. I started it yesterday and after it got warmed up it was smoking like a chimney. it was white smoke and it was very thick. i was just wanting to now where to start. It starts fine but it idles a little rough. i was just wanting your opinions on where to start before I tear in to it myself. I do have the technical manual form Kawasaki but i think you guys are smarter. I appreciate all the help!
Jared
Ya might just be surprised before it's all said and done :woohoo:
As was suggested, check for gas in your oil. It may be just that simple.
Larry C.
Last edit: 26 Mar 2013 22:58 by LarryC.
  • jared55b69
  • jared55b69's Avatar Topic Author
Re: 1978 kz 1000 A2
08 May 2013 01:54
#586257
Well I got the smoking issue resolved. I believe it was a little oil in the gas. It has stopped smoking. It was still running rough and not wanting to idle. It hesitates on acelleration and cuts out and back fires. So I took the carbs off and cleaned them and the air filter, and the plugss. I also did the mechanical adjustment because 2 of them were not at .7 mm adjustment. I put it all back together and it still does the same thing. It runs somewhat smooth until you accelerate. I need some help. Please. I Dont have baffle either.
Re: 1978 kz 1000 A2
08 May 2013 08:25 - 08 May 2013 08:25
#586281
Has the clear tube test been performed on each carb? If not, the fuel level may be too high, regardless of the dry-measured float height.
Good Fortune! :)
Last edit: 08 May 2013 08:25 by Patton.
  • bluej58
  • bluej58's Avatar
Re: 1978 kz 1000 A2
08 May 2013 08:33
#586283
Have you looked at the points, checked the gaps ?
Maybe the advance is giving you some trouble.
78 KZ1000 A2A
  • jared55b69
Re: 1978 kz 1000 A2
08 May 2013 10:06
#586299
Sometimes when it idles it will almost stop and make a metallic click and then start running again.I think it has electronic ignition. It does not look like points.
  • havakaw
  • havakaw's Avatar
Re: 1978 kz 1000 A2
08 May 2013 17:11 - 08 May 2013 17:11
#586377
If it's old and has some miles on it,the valve seals may be shot,especially if it has been sitting for some time.
'80 KZ 750 LTD-H
'82 KZ 1100 A-2 Shafty (ex-bagger)
Last edit: 08 May 2013 17:11 by havakaw.
  • newOld_kz1000
  • newOld_kz1000's Avatar
  • FlimFlamFlibbityFlee !! BoonFryedShickaMuhZee !!
Re: 1978 kz 1000 A2
08 May 2013 18:25 - 08 May 2013 18:29
#586389
jared55b69 wrote: Well I got the smoking issue resolved. I believe it was a little oil in the gas. It has stopped smoking. It was still running rough and not wanting to idle. It hesitates on acelleration and cuts out and back fires. So I took the carbs off and cleaned them and the air filter, and the plugss. I also did the mechanical adjustment because 2 of them were not at .7 mm adjustment. I put it all back together and it still does the same thing. It runs somewhat smooth until you accelerate. I need some help. Please. I Dont have baffle either.
I would check the large round 'thumb wheel' in the middle of the carbs at the top -- if it's not idling, screw in the thumbwheel until it does.
It's very easy to turn that thumbwheel and get exactly the same 'won't idle'/mechanical clicking noises' symptom.
I have a '78 Kz1000A2, I know *exactly* what that mechanically noisy sound sounds like, so does everyone here on the board, it's the "pre-stall grinding" noise that you hear right before the engine stalls, and is not a big deal, just turn in that thumbwheel and get it idling.
Now, if by turning that idle-set thumbwheel at the middle/top of your carbs, you can only get it to keep running at, say, 2000rpm but no lower, you may have a blocked pilot jet in one or more of your carbs, it's *easy* for them to get blocked.
I would search this forum on "pilot jet" or "pilot jet clean" and find a prior post that explains how to clean the pilot jet and the rest of the carb -- the pilot jet is the part of the carburetor that helps the engine keep running at idle.
YOU CAN SEE THAT BIG ROUND IDLE-SET THUMBSCREW AT THE TOP-MIDDLE OF THE Kz1000 CARBS HERE, RIGHT NEXT (TO THE IMMEDIATE LEFT and AT THE TOP OF) THE 3RD CARB THERE, IT HAS A + IN THE MIDDLE OF IT
1978 kz1000 A2 with Kerker
1980 Z1 Classic with Kerker
Last edit: 08 May 2013 18:29 by newOld_kz1000.
The following user(s) said Thank You: jared55b69
  • jared55b69
Re: 1978 kz 1000 A2
17 May 2013 08:19
#587867
well after all this help my kz is runnig really well. it still has some backfireing issues on deacceleration and warmup. I do not have a baffle. it has a kerger 4 into 1 on it. i thought about trying to put a better jet kit on it. Any suggestions?
  • HOGEATER
  • HOGEATER's Avatar
  • Been riding 2 wheels since 1965,
Re: 1978 kz 1000 A2
17 May 2013 16:11
#587952
Have you checked the vent from the head to the small filter/vent on the engine mid point under the carbs?? If that vent is blocked or hosed kinked ,it will cause back pressure in the engine.
HOGEATER(CHUCK)
Re: 1978 kz 1000 A2
17 May 2013 21:09 - 17 May 2013 21:09
#587992
jared55b69 wrote: ...some backfireing issues on deacceleration....?
Slightly enrichening the pilot circuits may reduce the exhaust popping on deceleration.
Good Fortune! :)
Last edit: 17 May 2013 21:09 by Patton.
