- Thank you received: 64
Home made Manual Cam Chain Tensioner
- undiablo
Thanks!
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
- mopguy
- Thank you received: 168
- undiablo
I went there once I finished the Kaw to get it blessed.
- mopguy
- 4TheKZ1000
- Visitor
- Thank you received: 2064
- undiablo
Mopguy, if you ever come back to visit Argentina, let me know so we can ride my KZ around.
- mopguy
- gdprather
- Thank you received: 3
1985 Kawasaki Vucan vn700A1
1983 Kawasaki KZ1100D2 Spectre
- baldy110
- Thank you received: 512
1. Take the tensioner off the bike and dissasemble.
2. Drill a 1/4" hole on the very back.
3. Install a 6mm x 1mm helicoil in the hole
4. Find a long enough 6mm x 1mm bolt with nut and install into the heli coiled hole.
5. Re-assemble the tensioner and install on bike.
6. After you adjusted the tensioner per the manual screw in the bolt on the back of the tensioner until it starts to get tight, (do this by hand no tools.)
7. Turn the engine over using the 12mm bolt under the ignition as you hand tighten the bolt behind the tensioner.
8. Keep doing this until all the slack is out of the chain. You will know because you will not be able to turn the bolt any more by hand, again, NO TOOLS.
9. Tighten the stock lock bolt and nut on the tensioner then tighten the lock nut on the bolt you just put on the tensioner and your done.
Total cost is about $15.00 for a machine shop to install the helicoil or if you already have a kit then about .50 cents.
- turboking
- Thank you received: 106
baldy110 wrote: Here is my version of a manual timing chain tensioner that I made using the stock one. I made this one in 1979 when I realized the stock one was not tightening the timing chain enough. I have used this tensioner for over 30 years with no issues.
we think alike :laugh: I did the same mod to my stock tensioner many years ago before the cool looking billet tensioners, not fancy but it does the job :ohmy:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
- undiablo
