- Thank you received: 3
Ignition advance removel
- gdprather
02 Mar 2013 18:26 #574919
by gdprather
1985 Kawasaki Vucan vn700A1
1983 Kawasaki KZ1100D2 Spectre
Ignition advance removel was created by gdprather
I have searched and haven't really found any for sure information on removing the ignition advance from my 1983 kz1100 Spectre. I was wondering if I remove the bolt and pulled the advance off will I have to worry about timing or does the advance go back on one way. I am powder coating the covers.
- donthaveakawman
- Visitor
02 Mar 2013 18:59 #574924
by donthaveakawman
Replied by donthaveakawman on topic Ignition advance removel
I think there is something on the archives about something similar to that maybe another forum, It's googleability is astounding. you would have to get another ignitor box from what I understand I think from a gpz.
- donthaveakawman
- Visitor
02 Mar 2013 19:17 #574931
by donthaveakawman
TOPIC: KZ750 - GPZ750 IC Igniter Mod
KZ750 - GPZ750 IC Igniter Mod 4 years, 8 months ago #221151
cafekz750
OFFLINE
From the The GPZ Modification FAQ
The 1984-85 900 Ninja has a 35 degree box with no rpm limiter (box # 21119-1111) that I use in the race bike. The 86-87 1000R Ninja has the 35 degree box "with" the rpm limiter at 10,600 rpm ( box # 21119-1165 ) that I use in the street bike. THESE BOXES WILL ONLY FIT IN THE 83-85 GPz750 models and work the same other than one having the limiter.
The 86-87 1000R Ninja boxes can be made to fit the 82 and "earlier" Kz/GPz750. But you'll also need to get the large "single" plug with 6" of wire attached that mates with this box.
So, this mod replaces the mechanical advance with a electronic version. I am assuming that in order to put it on a KZ750 you would ALSO have to toss the mechanical advance and pickup coils and replace them with ones from a GPZ (single plate and trigger) along with the Ninja IC Igniter box. Correct?
Is there something I am not seeing?
1981 KZ750H2 - V&H 4-1 pipe, pods, jetted, clubmans, homebrew rearsets, 18" rear wheel and more.
Parting out a 1982 KZ750H3 to fund future projects
2 other non-Kawasaki motorcycles
Report to moderator
Quick Reply Reply Quote
Thank You
cafekz750
OFFLINE
Report to moderator
Thank You
- gdprather
02 Mar 2013 19:31 #574933
by gdprather
Replied by gdprather on topic Ignition advance removel
I am sorry if I did not make it clear. What I am trying to do is just remove the mechanical advance off the crank so i can powdecoat the housing. I was just wondering if I unbolt it from the engine if I would have to deal with resetting the timing or will the unit just slide back on?
- donthaveakawman
- Visitor
02 Mar 2013 19:44 #574935
by donthaveakawman
ok, let me get some reading glasses, sorry. I don't think it would be a problem. being a 83 it should have electric ignition not points so no it is not adjustable as far as I know. just make sure you don't put it on backwards.
- MFolks
- Thank you received: 540
02 Mar 2013 19:51 #574939
by MFolks
Replied by MFolks on topic Ignition advance removel
Make note, or mark with a "Sharpie" where it goes. If you forget,re-install it and try to start the engine, if no fire, you're probably 180 out, so remove & install correctly.
- gdprather
02 Mar 2013 20:47 #574952
by gdprather
Okay, thank you. I assumed it would not be a problem but I have never removed one before. Thanks again.
- MFolks
02 Mar 2013 21:21 #574954
by MFolks
Remove the center bolt(maybe a 12-13 mm)and then slip the advancer off the end of the crankshaft. You might have to give it a slight twist to clear the slots where the advancer weights go, but it should come off easily.
- gdprather
02 Mar 2013 21:31 - 02 Mar 2013 21:32 #574959
by gdprather
Ok I put a 12mm socket on the center bolt and a wrench on the 17mm and I could not move it at all. Well seems as though it may be moving very little but comes to a stop. I dont want to break the bolt.
Last edit: 02 Mar 2013 21:32 by gdprather.
- gdprather
02 Mar 2013 21:33 #574960
by gdprather
Is that bolt a right handed thread?
- steell
02 Mar 2013 23:34 - 02 Mar 2013 23:34 #574995
by steell
Replied by steell on topic Ignition advance removel
Yes it's right handed. Tap it with a hammer, try and soak it in a 50/50 mixture of acetone and auto trans fluid overnight, then tap on it a few times before trying to turn the bolt.
You don't want to break that bolt, it goes in the end of the crank.
Might even try a few gentle taps on a hammer impact (hand held kind you smack with a hammer).
Last edit: 02 Mar 2013 23:34 by steell.
- etbike3135
- Thank you received: 50
03 Mar 2013 00:16 #575000
by etbike3135
1973 Kawasaki Z1
18 years in dragbikes
Replied by etbike3135 on topic Ignition advance removel
Put a wrench on it and knock it with a rubber mallet. A impact is really the trick but hitting it will work too.
1973 Kawasaki Z1
