D PORTING KZ HEAD
02 Mar 2013 09:50 #574875 by LarryC
Replied by LarryC on topic D PORTING KZ HEAD
prostreetkz wrote: I'm truly honored to have you on my discussion, Larry. Now I'm going to get somewhere, lol, That's interesting on the exhaust side, I have read similar info on the exhaust side for porting , really just polishing the exhaust side, maybe a little match porting is sufficient. I want to pick your brain on D porting the intake side. I have read you say it's only needed if the port size is large. First off tapering a port runner, being larger on the carb end and smaller on the valve end will indeed increase velocity is that what the idea is to do? I have a 37.5 intake valve, shouldn't 40mm rs mikunis theoretically work well? Match porting the carb slowly tapering the port to the intended throat size of 89% then blending that to the bowl in turn to the valve seat? I would love to talk to you on the phone , I have also posted this same topic on your forum , again thx larry. I have rs40 mikunis but Have realized I may need 36 or maybe 38s.Cams have 485 at .040, 37.5in 33ex 76mm bore kz 900 crank. I am wanting peak power around 95-10000 but is that to high with heavy stainless valves and steel retainers? about 60% strip 40% street. I think that's all your needing for CSA values Thx Larry
36mm carbs will do the job, 38's really ought to have a J head. 40's are total overkill for the size of the engine IMO
Larry C.
22 Apr 2013 07:21 - 22 Apr 2013 07:38 #583511 by LarryC
Attachment 2013-04-1915.29.51.jpg not found
Here's the result. It's heading home to you today Alan...
38.6 APE GPz11 Intakes turned down to 38.
KW exhausts Springs
Cam Motion Z10 Grind Cams .485 lift [101CFM@that lift@10"] Tested with the intake boots it will run.
APE Guides
OEM 650 Retainers
Valve Job setup for 280-285 shims to avoid the tendency of fracture that is so often seen with thin shims being used in a high performance application.
Normally I would have reduced the velocity a bit more to 270ish. Cams, compression ratio and bore size play into the equation.
Should make plenty of torque ;)
Attachment 2013-04-1915.25.14.jpg not found
Attachment 2013-04-1915.27.28.jpg not found
Attachment 2013-04-2009.46.17.jpg not found
Attachment 2013-04-2011.29.38.jpg not found
Attachment 2013-04-1915.26.40.jpg not found
Larry C.
Last edit: 22 Apr 2013 07:38 by LarryC.
22 Apr 2013 21:06 #583604 by racer54
Replied by racer54 on topic D PORTING KZ HEAD
It really amazes me how you can get those port walls so even looking without any grinding marks showing. Craftsmanship at its best. Nice job!
The following user(s) said Thank You: LarryC
22 Apr 2013 23:36 #583630 by zukdave
Replied by zukdave on topic D PORTING KZ HEAD
Racer that's why I talked to Larry around the first of the
year about doing my GPz750 head.
I just need to finish rounding up part's to send him
with the head.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
22 Apr 2013 23:42 #583633 by prostreetkz
Replied by prostreetkz on topic D PORTING KZ HEAD
Yes Larry is the best !!! I can't wait to get the head back !! This bike is going to be an absolute beast!!!!!
THX LARRY
23 Apr 2013 00:13 #583640 by Hollywoodmx
Replied by Hollywoodmx on topic D PORTING KZ HEAD
That is bad ass. What's that all worth?
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
25 Apr 2013 08:12 #583931 by LarryC
Hollywoodmx wrote: That is bad ass. What's that all worth?
You mean in terms of power?
Larry C.
25 Apr 2013 17:52 #584006 by Hollywoodmx
No the cost of parts and work but now that you mentioned it power gains too.
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
25 Apr 2013 18:50 #584013 by LarryC
prostreetkz wrote: Yes Larry is the best !!! I can't wait to get the head back !! This bike is going to be an absolute beast!!!!!
THX LARRY
You're welcome :)
Larry C.
