Wiesco piston slap!
  • APE Jay
  • APE Jay's Avatar
Re: Wiesco piston slap!
20 Apr 2013 19:52
#583349
Motor Head wrote: A thou and a half clearance? Doubt it. I can't think of any machinist who would set up a big bore KZ motor to that spec. Might be time to have a second opinion on the clearance. Take it over and have it measured somewhere else, if you don't have the tools.
.0025" would be more like it. After boring the final honing will set the clearance, and it needs to be done with a precision hone so the bore is true. No flex hones or balls.
Was the bore kit the only work done at that time? Was there engine noise before the work?
We do Wiseco 1075 at thou and a half. Have since Wiseco cam out with the kit. Don't know if it is "thousands" like the other guy, but I'll bet it is close.
You can do that with the 4032 alloy.
