- Thank you received: 9
Head Removal
- Spectre1982
1982 Kawasaki KZ750 Spectre
1978 Kawasaki KZ200
1985 Yamaha XV1000 Virago
(Avatar picture is from Alleycatscustoms.com)
- Spectre1982
Thanks!
1978 Kawasaki KZ200
- wireman
- Thank you received: 299
Why are you removing the head?
- bountyhunter
- Thank you received: 337
Uless you seal it with 3-bond or yamabond or something similar.wireman wrote: Once you break the seal on the bottem gasket by prying on the cylinder you might as well go ahead and pull the cylinder and replace the base gasket or chances are youll have a leak.
- Spectre1982
I already bought all new gaskets. That was part of the plan.
1978 Kawasaki KZ200
- Motor Head
- Thank you received: 391
- wireman
When you fill the ports with solvent blow air around edge of valves where they meet seats and look for bubbles in solvent.Motor Head wrote: While you have the head off, I would do at least a solvent check of the valves. Pour some light solvent/ gas/ brake clean/ or even diesel into each port. Looking at the valves in the combustion chamber to see if they leak. Then you can determine the next course of action there. But at minimum I would replace the valve stem oil seals and lap the valves back into the seats. Better to get the head rebuilt. Also the Teflon Stem Seals would be best, as they will give many years/ miles of good service. You'll need to take a measurement of the valve clearances, make a Map of it, and after the head is done re-shim the clearance. Keep all the shims and buckets in order to go back where they were to start out.
- floivanus
- Thank you received: 116
Past; 78 kz1000, 83 kz550
Andrew
- wireman
- Spectre1982
1978 Kawasaki KZ200
- natetru
1982 kz1000 m2 csr
- wireman
Put the copper coat on both sides of new gasket before installing.
