Oil Pressure light is on !!!!
- Powerstroke_fan
Re: Oil Pressure light is on !!!!
15 Feb 2013 21:29bountyhunter wrote:Yep. That would worry me enough to buy or rent an oil pressure gauuge to isntall at the hole where the sender is. I have one I bought way back when.650ed wrote: If it is in fact an oil pump problem it could be that the light comes on after the oil gets hot and thins down a bit. Ed
That part:
he suggested either the switch is bad (switch, or wiring), or the filter (to the pump? not the main oil filter) is clogged thanks to the water foam that we've been slowly working out of the block
would really scare me. I would have risned the water out with solvent and blown it clean. Water and oil don't mix... literally.
I would also reccomend getting a pressure guage. Or you could just remove or loosen the bolt a little while idleing and see if the oils flowing. But it might get kinda messy. also dont run it very long and run it out of oil.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
15 Feb 2013 22:36
You have water contaminating the oil? Step 1 - change the oil before you ruin the engine. Ed
- zukdave
15 Feb 2013 23:31
I think I'd change the dude working on his bike.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- mcmelend
15 Feb 2013 23:34
650ed ... I have changed the oil twice. nice and foamy white.
I just can't afford to rebuild the motor. Maybe in a few years... as for now i'm milking my piggy bank.
I checked the wiring from the switch to the harness, doesn't look like there's any shorting. I believe the problem is with the oil pump screen. So i hope my local kawi shop has the oil pan gasket so i can drop the pan and clean the screen.
Do i absolutely need a new gasket? or can i just use the old one to drop the pan and clean the screen?
1979 Kz750 Twin.
Behold Asian Ingenuity!
- baldy110
18 Feb 2013 14:21
I have re-used old gaskets in a pinch as long as the gasket comes off clean with no breaks. If it breaks upon removal then I would get another one.
- bountyhunter
18 Feb 2013 18:14 - 18 Feb 2013 18:16mcmelend wrote: 650ed ... I have changed the oil twice. nice and foamy white.
If it's like my 79 750, the pan gasket will tear to shreds upon removal. I had to use a sledge hammer to get the pan off. You can buy the gasket material at Pep Boys and make one for a couple of bucks. Can probably get an OEM one off ebay for maybe $10 ballpark.
Last edit: 18 Feb 2013 18:16 by bountyhunter.
- aek
19 Feb 2013 15:56
I think the reason your oil light takes some time to come on is due to the original condition of the water and oil you have in the crankcase. The oil and water will try to separate and for the first mile or so the pump is pumping a liquid albeit one you don't want. It soon emulsifies and becomes a combination of water, oil and air. The pump cannot maintain pressure or maybe suction and there can't be much oil support in the bearing interfaces in the engine. I think it's urgent that you get this stuff out of the engine before you run it again. I would suggest removing the oil pan and the clutch cover and spraying cleaner up into the engine and transmission. I would use kerosene for this job.
Hope this is helpful.
art
art
1980 750-4 LTD original owner
- mcmelend
19 Feb 2013 16:46
Hey aek
i totally agree ! - i got to thinking about it, when the oil becomes that frothy white crap it can't pressure properly hence the light kicking on later...
i've changed the oil 3 times since owning the bike, but i plan to take it to my mechanic and let him pull the pan and clutch cover like you said and clean those bad boys out, pluss clean the oil pump screen... bet it's crapped over.
1979 Kz750 Twin.
