Engine Compression
- LarryC
Re: Engine Compression
01 Feb 2013 23:57Spectre1982 wrote: Checked the compression in my engine yesteday. My shop manual says the minimum should be 124 PSI and not deviate more than 14 PSI between cylinders. The spark plug in No. 1 cylinder looked a bit oily. The other three were normal. Here are the readings.
1 - 100 2 - 110 3 - 120 4 - 110
This set of numbers was taken after putting a little oil down the spark plug hole.
1 - 122 2 - 118 3 - 125 4 - 120.
What do I need to do to restore my compression? I'm hoping new rings is all I need. When replacing the rings do I buy a standard set?
Thanks.
An oil injector for cylinder #1 ought to do it
Larry C.
- donthaveakawman
01 Feb 2013 23:58
did you have the throttle open for the compression test??
- bountyhunter
02 Feb 2013 03:08
carbs were not attached so throttle doesn't apply
- donthaveakawman
02 Feb 2013 07:43
yeah, I was a little late so I just read the title.
- APE Jay
