Valve Clearance
  • martin_csr
  • martin_csr's Avatar
Re: Valve Clearance
18 Jan 2013 22:54 - 23 Jan 2013 14:29
#568110
Search ebbaayy for KZ750 Shaft Manual - there are plenty of them. The ones I've seen have a Spectre on the front cover. Kawasaki factory manuals have a model application chart on the back cover - some sellers include a photo of the chart.
Last edit: 23 Jan 2013 14:29 by martin_csr.
  • Spectre1982
  • Spectre1982's Avatar Topic Author
Re: Valve Clearance
19 Jan 2013 12:09
#568157
Thanks for the replies. I'm going to go ahead and tackle the job. :)
1982 Kawasaki KZ750 Spectre
1978 Kawasaki KZ200
1985 Yamaha XV1000 Virago
(Avatar picture is from Alleycatscustoms.com)
  • Spectre1982
Re: Valve Clearance
22 Jan 2013 19:16
#568698
Do I need to remove the shims and measure them to determine what size I need on the new ones?
1978 Kawasaki KZ200
  • bountyhunter
  • bountyhunter's Avatar
Re: Valve Clearance
23 Jan 2013 00:49 - 23 Jan 2013 00:52
#568761
Make a drawing and measure all the clearances before you take it apart, record them. Then measure each shim as you take it out (keep them in order) and write that down on the drawing. that tells you what shims you will need by subtracting.
NOTE: if yours is shim-over-bucket you can get a tool and take the shims out only at the ones that need adjusting. If it's shim under bucket, the cams have to come out then take off the buckets at the locations that need adjusting. Keep the buckets and shims in order, measure the shims and calculate the one you ned.
Last edit: 23 Jan 2013 00:52 by bountyhunter.
The following user(s) said Thank You: Spectre1982
