Exhaust coming through the pod filters?
  • KraZyRIDER
  • KraZyRIDER's Avatar
Re: Exhaust coming through the pod filters?
25 Oct 2012 00:09
#555662
Austin440 wrote: However, when I shut it off, I noticed exhaust coming out of the pod filters.
...am I reading this right? You said filters? Are they all leaking at once? If so, it would be impossible for exhaust to leak out of all four at once. I'm not even sure if it's possible to leak exhaust out of one. Even when the engine runs backwards, it blows fuel vapor out the filters, not exhaust. My Sportster does it all the time when it's extremely hot out. Anything over 95˚and I'll get a bit of backwards run for a couple of turns after shut down.
...I'm with 893cv on this one. Before I got half way through your post, I was thinking fuel. First thing I would do, is check your float levels, make sure they're not too high. Then balance and adjust the carbs. Make sure you didn't miss anything when you were in there. Is there any fuel leaking from the overflow tubes? Just a thought.
Mean Green Speed Machine!
1979 KZ 650-C3 (Cafe Project)
1982 GPz 750-R1
1981 GPz 1100-B1
2005 H-D XL1200C
2006 H-D XL1200C
  • testarossa
  • testarossa's Avatar
25 Oct 2012 09:43
#555702
I'm surprised that no one has recommended this yet given your compression test results. You should try to adjust your valve clearances and then redo your compression test. Tight valves will cause lower compression. I wouldn't be too concerned about the vapor coming out through the pods.
www.kz400.com/KZ440MaintainanceFrameset.html
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • Austin440
  • Austin440's Avatar Topic Author
25 Oct 2012 13:51 - 25 Oct 2012 14:05
#555716
I probably shouldn't have said "filters" plural. It comes out of either one or the other. My Dad had mentioned that cars, and I'm sure some motorcycles, have evap canisters that reuse unburnt vuel vapors, so I'm thinking that's what I'm seeing out of the pod filters - it just looks like exhaust.
1981 KZ440 LTD
Last edit: 25 Oct 2012 14:05 by Austin440.
  • KraZyRIDER
25 Oct 2012 18:36
#555740
Austin440 wrote: I probably shouldn't have said "filters" plural. It comes out of either one or the other. My Dad had mentioned that cars, and I'm sure some motorcycles, have evap canisters that reuse unburnt vuel vapors, so I'm thinking that's what I'm seeing out of the pod filters - it just looks like exhaust.
...have you ever pulled the filters and watched what happens after shutdown?
...fuel vapors are easily identifiable.
1982 GPz 750-R1
1981 GPz 1100-B1
2005 H-D XL1200C
2006 H-D XL1200C
