sprockets and chain done, but i am worried...
16 Sep 2012 10:59 #549030 by shimkus
Attachment sprock001.JPG not found
yesterday I did the drive sprocks and chain on my 650. the only thing was that the new sprocket left a gap between the wheel hub and the holes on the sprocket(as pictured). will this be a problem? if so, what needs to be done to correct?
also, the chain did not fit right it seemed on the front sprockets. i am currently opening up the casing and going to remove the nut, loosen the chain an try to reset the sprocket. If its a bad idea, anyone speak up. thanks agaiin, guys!
'81 kz650h1
'88 el250-d
  • KZQ
  • Administrator
16 Sep 2012 11:06 #549032 by KZQ
Align the rear wheel but don't just go by the marks on the swingarm. If the rear wheel is properly aligned you can pull the chain guard off and visually check the alignment of the chain all the way up to the countershaft sprocket. The space you're pointing to isn't good. Where'd you get the sprocket?
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • trianglelaguna
16 Sep 2012 11:33 #549036 by trianglelaguna
Replied by trianglelaguna on topic sprockets and chain done, but i am worried...
can you post a better picture?
when i do a chain and sprocket it should go in just as the one before was....any difference is not a good sign and will rub or break something usually...
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
16 Sep 2012 11:35 #549038 by shimkus
Replied by shimkus on topic sprockets and chain done, but i am worried...
i got it on ebay its a jt fit the exact specs but i have a bad feeling bout it too... fuck.
'81 kz650h1
'88 el250-d
  • trianglelaguna
16 Sep 2012 11:43 #549042 by trianglelaguna
can you post a pick of the two side by side...i'm not getting where the space came from
did the old sprocket have counter sunk holes or what
1976 KZ900
2003 ZX12R
2007 FZ1000
The following user(s) said Thank You: wireman, shimkus
  • wireman
16 Sep 2012 11:54 - 16 Sep 2012 11:55 #549045 by wireman
Replied by wireman on topic sprockets and chain done, but i am worried...
Are the bolt holes on that sprocket slotted or am i just seeing things? :blink:
Oh wait a sec,thats one of the tabs not folded over! :laugh:
We need a better picture B)
Last edit: 16 Sep 2012 11:55 by wireman.
  • wireman
16 Sep 2012 11:57 #549046 by wireman
Is the area on the hub flat all the way around or are there bosses sticking up where sprocket bolts on? B)
16 Sep 2012 11:58 #549047 by Patton
If needed, this link downloads the KZ650 service manual.
www.scribd.com/doc/48655900/Kawasaki-KZ-...B1-77-Service-Manual
This excerpt is from page 109.
Good Fortune! :)
  • wireman
16 Sep 2012 12:01 #549049 by wireman
Attachment 650wheel.gif not found
  • 4TheKZ1000
  • Visitor
16 Sep 2012 12:42 #549062 by 4TheKZ1000
Replied by 4TheKZ1000 on topic sprockets and chain done, but i am worried...
it sounds like it didnt seat on the hub....the raised radius of the hub and hole of sprocket are binding up....maybe. could use a round sanding hub on a drill and releive the hole on the sprocket a tiny bit.
16 Sep 2012 12:56 #549064 by shimkus
the thing is, the original (stock) sprockets are more rectangular while the new ones are rounder... possibly the older hubs were larger or maybe its for a mag, not aluminum spoke.. shit i put up one tab on each locknut, switched to the unused ones and they were wicky woo to begin with lol
'81 kz650h1
'88 el250-d
  • 4TheKZ1000
  • Visitor
16 Sep 2012 13:02 - 16 Sep 2012 13:11 #549066 by 4TheKZ1000
The hub and sprocket are tight tolerances and need to be just right. I powdered coated my sprocket and it wouldn’t seat the hub. I had to remove the PC. Can you sand the radius of the sprocket abit to open up hole.....not to much, should be able to seat sprocket by hand a turn it when seated with abit of tension....dont touch the hub. I went to a round hole sprocket....dosent mean anything...its the dia of the sprocket hole.
Last edit: 16 Sep 2012 13:11 by 4TheKZ1000.
