Why is oil leaking from here!!!
- TheJoshManKZ
31 Jul 2012 18:56 #539802
by TheJoshManKZ
1980 KZ750E1
Why is oil leaking from here!!! was created by TheJoshManKZ
Idk what the heck this hole is, but motor oil looks as though it is boiling and leaking/spitting out of it. It gets messy quick and is very annoying and potentially dangerous. Please help!!
Attachment 1343771680426.jpg not found
Attachment 1343771611462.jpg not found
1980 KZ750E1
- 4TheKZ1000
- Visitor
31 Jul 2012 18:59 #539803
by 4TheKZ1000
Replied by 4TheKZ1000 on topic Why is oil leaking from here!!!
a bolt or screw came out...
- wireman
- Thank you received: 299
31 Jul 2012 19:01 #539804
by wireman
Replied by wireman on topic Why is oil leaking from here!!!
It needs a bolt with stop nut on it
- Tomolu5
- Thank you received: 45
31 Jul 2012 19:02 #539805
by Tomolu5
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
Replied by Tomolu5 on topic Why is oil leaking from here!!!
Don't know the model off hand, but it sure looks like the bolt for the camchain tensioner goes in that hole, wouldn't recomend running it till that is verified/fixed
Mine:
- 4TheKZ1000
- Visitor
31 Jul 2012 19:04 - 31 Jul 2012 19:05 #539806
by 4TheKZ1000
its the ( tensioner Adjust Bolt) you need to fix this before running the engine. dont run the engine.
Last edit: 31 Jul 2012 19:05 by 4TheKZ1000.
- Thank you received: 2829
31 Jul 2012 19:05 - 31 Jul 2012 19:08 #539807
by 650ed
Replied by 650ed on topic Why is oil leaking from here!!!
It's leaking because you are missing the bolt that belongs in that hole and its washer. That is your cam chain tensioner, and I would suggest you check to see how you are suppose to adjust it because as it is now I would expect your cam chain to be out of adjustment. Here's the picture of what;s missing:
Attachment 00000_2012-07-31-3.jpg not found
Last edit: 31 Jul 2012 19:08 by 650ed.
- tinlizzie37
- Thank you received: 1
31 Jul 2012 21:50 #539852
by tinlizzie37
Bob KZ 650 E1, En 450
Replied by tinlizzie37 on topic Why is oil leaking from here!!!
Hi Josh, You have the good double wedge automatic tensioner. You just need a short bolt and washer to cap it. Don't use a long one or it will keep the plunger from going in against the cam chain. The original bolt was used to screw into the hole without the washer. This would keep the push rod from coming out when you remove the tensioner. With the washer on, the bolt doesn't touch the push rod, and lets it float. Bob
- TheJoshManKZ
01 Aug 2012 20:01 #540077
by TheJoshManKZ
1980 KZ750E1
Replied by TheJoshManKZ on topic Why is oil leaking from here!!!
Thanks so much for the help guys! Luckily I was able to order it from a dealership. I've been riding it for a couple of weeks like that
1980 KZ750E1
- Thank you received: 1656
02 Aug 2012 12:29 - 22 Jan 2013 20:51 #540254
by martin_csr
Replied by martin_csr on topic Why is oil leaking from here!!!
I would remove the tensioner, check & lubricate it, & reinstall as per the factory manual. You may need to get a new gasket. Ape or Krieger manual tensioners
Last edit: 22 Jan 2013 20:51 by martin_csr.
- TheJoshManKZ
03 Aug 2012 20:04 #540587
by TheJoshManKZ
1980 KZ750E1
How easy is that? I'm pretty new to the motorcycle mechanics world
1980 KZ750E1
- peter1958
- Banned
- Thank you received: 198
03 Aug 2012 20:37 #540598
by peter1958
Replied by peter1958 on topic Why is oil leaking from here!!!
nothing too it
- roy-b-boy-b
- Thank you received: 103
03 Aug 2012 21:39 #540606
by roy-b-boy-b
Replied by roy-b-boy-b on topic Why is oil leaking from here!!!
If the engine is not making a lot of noise I would install the bolt and ride on. But that is just me.
