Sprocket-cover cracked! Wy?
- GreatDane
Today i finally got my '79 Z650 on the road, hooray! I went for a short run on some backroads (around 40 miles), and after around 30 miles I got a squeeky sound when I pulled in the clutch-lever, some times more, some times less. I decided to head home, and around 2 miles from home I pulled the clutch again, stopping in an intersection, and my sprocketcover cracked!! :blink:
Can anybody tell me what the f... is going on?
Pretty bummed right now, need to go hunting for a new cover or somebody with welding-equipment for doing it back up?
- MFolks
- Thank you received: 540
Motorcycle Salvage Companies
www.cycle-salvage.com
www.motorcycle-recycle-center.com/
www.newrivercyclesalvage.com/index.html
www.bornagainbikes.net/
www.motolane.com/
www.williescycle.com/
- GreatDane
Thanks again
- Garn
- Thank you received: 13
1 x 73 Z1 (Jaffa), 74 Z1A, 76 Z900-A4
1 x 73 Yamaha TX500 & 98 fzx250 Zeal
Sydney Australia
- damarble
Go green, buy a Kawasaki!
82 KZ750M CSR Build Thread
89 ZX600C Streetfighter
- GreatDane
Garn: I believe the bolts were evenly tightened, but off course, with this happened, I've been wondering about it too.
I finally got the time to pull the cover of today, I thought it had only cracked on the upper half, so I wanted to bring to a local shop that I use for other jobs (job-related stuff), that I believed could weld it. When I took it off, I found out that the bolthole on the lower front was ripped off too, so I think it's impossible to save now. The other thing i found out was that my pushrod was bend (the part that sticks out of the engine), and that the bearing-ball on the other end was worn flat, and in some way stuck to the end of the pushrod, maybe that's part of the problem?
- Thank you received: 2829
- 2wheeladdict
- Thank you received: 3
80 KZ1000 LTD
81 Yamaha XJ650 maxim
84 CR60r
- GreatDane
2wheeladdict: Sorry, as mentioned above I'm all new to wrenching old bikes (or any bikes for that matter, used to be into cars). Can you explain to me more specificly what that is, how it works, where I can get it and such?
- mtbspeedfreak
- Thank you received: 36
GreatDane wrote: 2wheeladdict: Sorry, as mentioned above I'm all new to wrenching old bikes (or any bikes for that matter, used to be into cars). Can you explain to me more specificly what that is, how it works, where I can get it and such?
+1
Where can you get one from?
2000 ZRX 1100
1976 KZ 900- Daily Driver
- jeffasaki
- Thank you received: 44
the ball on the end of the rod friction welded itself to the pushrod
it the spins with the clutch
which turns the clutch actuator in the sprocket cover
and pushed the cover out til it cracked
it was my fault for over reving the bike
you gotta check the clutch side for damage as well
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- 2wheeladdict
80 KZ1000 LTD
84 CR60r
