Kz1000 ticking, knocking, and burning?
  • Drew420
  • Drew420's Avatar Topic Author
26 Jun 2012 12:12
#531871
My 82 kz1000 started ticking or knocking inside the engine. Starts of low but when giving it gas it speeds up. Might have been low on oil so I put a little in and now it smells like oil or grease burning. Does anyone know what this could be?
that's a video so you can hear what i'm talking about. Please help.
  • ldizzle
  • ldizzle's Avatar
Re: Kz1000 ticking, knocking, and burning?
26 Jun 2012 12:32
#531875
Could be the valves are too tight or the timing is off.
There's worse scenarios...but these are usual on motorbikes.
bump for mas help!
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
26 Jun 2012 12:36
#531878
First thought is valve adjustment. Does the bike get regular maintance ? Do a oil and filter change and try it again. Then let us know. Dont run it hard until you at least that done
  • Drew420
26 Jun 2012 12:55
#531883
I gave the bike an oil change about a month ago. When I checked it yesterday the oil was looking a little low. At first I thought if I put a little oil in it the ticking would go away but it didn't. Haven't checked the valves yet.
  • Tomolu5
  • Tomolu5's Avatar
26 Jun 2012 13:36
#531889
+1 on the valve checking.
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
26 Jun 2012 14:29
#531896
I got $5 says you bent a valve or spun a rod. If it is, hope it's the bent valve but I'm leaning towards rod. :ohmy:
Les
  • faffi
  • faffi's Avatar
26 Jun 2012 14:52
#531905
Exhaust leak can also make a horrible, mechanical sound so make sure there's no leak between the headers and engine.
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
26 Jun 2012 15:18
#531910
Retract on rod knocking, just seen it's a 1000, I thought it was a 750. :blush:
Les
  • P21
  • P21's Avatar
26 Jun 2012 15:36
#531914
do a compression test (dry) then (wet) and see what is going on
its hard to tell with that muffler set-up
could be a cracked ring that would be your burning
Kawasaki KZ 1000 Police (2002) P21
  • wireman
  • wireman's Avatar
26 Jun 2012 16:27
#531928
Drew420 wrote: My 82 kz1000 started ticking or knocking inside the engine. Starts of low but when giving it gas it speeds up. Might have been low on oil so I put a little in and now it smells like oil or grease burning. Does anyone know what this could be?
Did the noise start before or after the burn out in your picture? :woohoo:
  • wireman
  • wireman's Avatar
26 Jun 2012 16:58
#531933
Check for an exhuast leak first,if that dont do it check under valve cover B)
  • Drew420
26 Jun 2012 21:23
#531993
i'll be checking the valves tomorrow. Thanks for the help everyone,
