Engine Forum
Engine forum is a tech forum for "Engine" topics.
Do i need a baffle?
  • rammy
  • rammy's Avatar
Re: Do i need a baffle?
08 Jun 2006 18:15
#53065
You can build a baffle for your pipe. I had to do that with mine after losen the orginal 1. called hooker header and said they quit making the header for my bike in '85 or so off to experminenting and finding dimentions I made mine out of stainless and sounds good. nice and quite when cruising but opens up and TALKS about 5500. Running and open can will get old real fast (too f@#Nin LOUD)AND i LIKE LOUD but after a coupl hrs of it screaming in your right ear you would wish it was quite.
The barn yard;77 Kz650B-1 Kaw(the fun one) & 89 classic hog.
Chicago area-south burbs
  • kzmarvo
  • kzmarvo's Avatar Topic Author
08 Jun 2006 18:54
#53072
How do you build a baffle?:S
Watch it folks,i have sticky fingers when it comes to a nice looking set of handle bars:)
  • Pterosaur
  • Pterosaur's Avatar
08 Jun 2006 22:33
#53118
ambergrismooon wrote:
... One of my mother-in-laws hates noise and I always thought a nice spot in the middle of a header war was just the right spot for her!:woohoo:.:evil:
Young Gris (...before the Wookie suit...) being taught to ride a '68 Moto Guzzi by a prospective (...before she wised up and bought a shotgun...) mother-in-law...
Post edited by: Pterosaur, at: 2006/06/09 01:36
  • Pterosaur
08 Jun 2006 22:52
#53121
...Then another mother-in-law would just plink your bikes with a BB gun when you left them unattended.....:evil:
Momma-in-law (...holding BB gun...) about to plink herself a Gris for asking if there was a 90 day money back plan on her daughter...
  • ambergrismooon
  • ambergrismooon's Avatar
09 Jun 2006 06:25
#53156
I don't know how you do it but you're so close to her real image it's scarey. She is this Granny Clampett doppelganger. She wore some combat looking boots with a sundress. Her daughter (ex#2) was a total opposite. OR so I thought until she walked in with a mowhawk and nose ring. She has ditched both now and has returned to the land of the almost normal. NOT that I would know what is NORMAL! But.... I am chief of the lost tribe of the Wherethefu**arewe's and comptroller of the "Sphincter of the Universe"! :woohoo:
Sorry about hijacking your thread kzmarvo!
Somebody tell this guy how to build a baffle please....
  • Pterosaur
09 Jun 2006 07:06
#53160
...Somebody tell this guy how to build a baffle please....
Okay, since I've run amok and generally made a mockery of things as usual, I'll step up.
As always, there's two ways - the easy way, and the hard way.
The easy way is to get yourself a hunk of perforated diamond-plate steel, have it cut to a circular pattern to fit the end of your pipe, with a couple of tab extentions to be bent over and drilled for bolts. Usually, there's a rivet hole or two near the end of production-made cans that held the original baffle in place. Arrange the tab extensions to fit the rivet placement, and you're outta there.
Just enough back pressure to be effective, and opaque enough to fool the odd Barney.
The "hard" way is an extension of the easy way. Get a second piece of diamond plate of smaller diameter that fits the tapered inner of your pipe. Get a hunk of 1-1/4" to 1/1/2" steel tube about 6" to 8" long and drill a pattern of holes in it 3/8" to 1/2" in diameter. Weld the tube between the diamond plates so it looks like a tapered spool:
|_________|
|ooooooo|
_________
Excuse the crappy ascii..
Slip the contraption into the end of your pipe and bolt it in place with the tab extensions as per the easy route.
Eeeeek! that *is* crappy *ascii*! :whistle:
[addendum]: Make sure that the inner (up the pipe) perfed diamond plate has about 1/4" clearance between its O.D. and the I.D. of your can - otherwise, when you fire it up, it's gonna sound like you go a swarm of pi$$ed-off *Keeeler Beez* up there lookin' for a target...
Viola!
Post edited by: Pterosaur, at: 2006/06/09 10:21
Post edited by: Pterosaur, at: 2006/06/09 11:06
  • cary
  • cary's Avatar
09 Jun 2006 09:39
#53184
for 35 bones, MAC will send you a nice chrome canister w/ baffle and mounting hardware. just make sure you have a collecter with the correct inside diameter
  • Unhinged
  • Unhinged's Avatar
09 Jun 2006 21:06
#53306
...LOUD PIPES SAVE LIVES...
  • 77KZ650
  • 77KZ650's Avatar
10 Jun 2006 07:37
#53376
07 MDP Rookie of the Year
  • 77KZ650
  • 77KZ650's Avatar
10 Jun 2006 07:40
#53379
hows that for a 2 min MSpaint pic of a baffle?:P
black is the pipe, red the steel plate(or sheet metal) and piece of pipe, and blue is drill holes
  • Pterosaur
10 Jun 2006 08:16
#53384
Egggggg-zactly! ;)
  • btchalice
  • btchalice's Avatar
10 Jun 2006 08:55
#53388
hey pt i have that movie with the granny on the bike
harold and maude
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
