- Thank you received: 2
sand in the crankcase GPZ 550
- dfinnegan71
1981 GPZ 550 mild custom
- turboguzzi
- Thank you received: 72
Then, always take the bike to be pressure washed around the fins and get more of the road grime off. Even if there's still dirt it will be wet and less likely to fall inside.
now that it happened, mmm... not so good. start with a strong vaccum cleaner to try and suck as much as you can and as a minimum, take at least the sump off and try to wash down the grit.
if it was a 900-1000 with a roller crank, wouldnt worry that much as its less sensitive to dirt particles but on a plain bearing motor like the 550, i'd be more concerned. depends really on you and how much of a risk you want to take. there's no magic method to make sure every little grain of sand got out other than splititng the cases.
- Thank you received: 2829
Attachment ForkOffwithcircles.jpg not found
- steell
Dump about a gallon of kerosene/diesel into the motor, all at once if possible, so it will splash around and hit everything, followed by about a gallon of used oil from your last oil change. After removing the sump of course. Then continue with your plans.
Good thing Kawasaki designed an oil filter into their motors, eh
- dfinnegan71
- dfinnegan71
- bountyhunter
- Thank you received: 337
- wireman
- Thank you received: 299
Oil pandfinnegan71 wrote: Thanks steell that's what I will try. When you say "the sump" you mean the oil filter right?
- dfinnegan71
- LarryC
650ed wrote: Sorry; I'm no help here; but I have a related question. How could one prevent the sand, etc. from falling into the crankcase? I assume (this could be a mistake) that the grit was somehow hidden in the area where the studs enter the bottom end and the recesses near them as circled in pic below. Are there other places where the grit hides? Would packing those areas with thick grease prior to dis-assembly hold the grit in place so it wouldn't fall into the bottom end? Thanks, Ed
Ed,
I love how clean you keep your bike!
Larry C.
- DoubleDub
- Visitor
Where did you get that pretty "spring" cover for your clutch cable? That looks like a well-thought addition...
DoubleDub - that's a genuine Kawasaki cable. I noticed that some of the aftermarket ones don't have the spring. I'm probably wrong, but I think the spring helps to keep the lower end of the cable sleeve firmly seated in the engine cover. Here's what the new old stock (NOS) KZ650 part looks like:
