big bore
  • baborz72
  • Topic Author
  • Not enough hours!
28 May 2012 12:12 #525349 by baborz72
big bore was created by baborz72
Hey everybody! May be getting another old kz soon. Tried the H.D. thing and not so impressed.... How large of a bore can you go on a 750 4cyl.???
It'll go...or...It'll blow!
  • wireman
28 May 2012 12:27 #525354 by wireman
Replied by wireman on topic big bore
Which 750? B)
28 May 2012 12:43 #525358 by les holt
Replied by les holt on topic big bore
I believe wireman is asking twin or 4 cyl. I know 4 cyl 750's go 810 with off the shelf kits and have seen 880cc done with some specialty stuff. Don't have a clue on the twins.
Les
  • wireman
28 May 2012 12:47 #525361 by wireman
Theres a lot of differant 750 4 cyls out there,Im not sure if they all use same piston kits or not is all. :)
  • baborz72
  • Topic Author
  • Not enough hours!
28 May 2012 12:51 #525363 by baborz72
Replied by baborz72 on topic big bore
it's a 1980 KZ-750....I believe it is an LTD. I can start with this and the larger block will bolt on later correct???
28 May 2012 15:35 #525393 by les holt
I believe 810 is in the stock block but the 880 is BIG Money and requires sleeves. Look on 750turbo.com, there is some 880 stuff on there or used to be.
Les
28 May 2012 15:48 #525397 by T_Dub
Replied by T_Dub on topic big bore
Just go to 810, 880 is too expensive. 810 can be done on the stock block with off the shelf pistons.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
28 May 2012 17:54 #525432 by 650ed
Replied by 650ed on topic big bore
You haven't answer the important question: Is it a 4 cylinder motor OR a 2 cylinder motor. It matters, and they made 1980 KZ750 LTD bikes in 2 and 4 cylinder models. Ed
28 May 2012 19:12 - 28 May 2012 19:12 #525448 by T_Dub
He said 4cyl in his original post, and his avatar is definitely a 750 LTD.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
Last edit: 28 May 2012 19:12 by T_Dub.
  • wireman
28 May 2012 19:17 #525450 by wireman
T_Dub wrote: He said 4cyl in his original post, and his avatar is definitely a 750 LTD.
looks like a 78 kz1000 in his avatar to me anyway! :laugh:
28 May 2012 19:25 #525453 by T_Dub
Haha, it sure does.
Anyways, read this: forums.kz650.info/index.php?topic=7051.0
I took a lot of time to write that. In the replies to that post we pretty much cover anything I missed in the original posting. If you still have questions ask after you read that. We've got a crack team over on kz650.info these days.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
28 May 2012 21:16 - 28 May 2012 21:17 #525488 by 650ed
Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 304. Please enable debug mode for more information.
