- Thank you received: 1656
clutch problems?
19 Nov 2012 11:28 - 23 Jan 2013 13:05 #559113
by martin_csr
Replied by martin_csr on topic clutch problems?
The owner's manual will have the procedure & it depends upon the bike. Some are clockwise first. Others, such as my 81 650 are counterclockwise first.donthaveakawman wrote: I always did it to the right then out a half turn, are you kidding me.
Last edit: 23 Jan 2013 13:05 by martin_csr.
- donthaveakawman
- Visitor
20 Nov 2012 20:49 #559352
by donthaveakawman
Replied by donthaveakawman on topic clutch problems?
looks awesome, be careful not to get a tire skid :silly: mark on your jeans.jason289 wrote: I cut a skateboard in half and shaped it like a seat.I don't know what a birdman seat is.I'ts more comfy than it looks.I saw somone do it in the"dirtbag challenge" thought it was a smart cheap way to make a seat.
- donthaveakawman
- Visitor
20 Nov 2012 20:53 #559353
by donthaveakawman
may need to readjust the clutch, I had it right then I read this, then adjusted it again and it's all good. No more slippage at high rpm's. That along with recharging the k&n seems to have done the motor good.(used a brush to get the oil inside the filter since the exposed side is inside the round filter). That filter really smelled like gas.
- Thank you received: 2098
20 Nov 2012 22:50 - 20 Nov 2012 22:51 #559371
by Patton
Replied by Patton on topic clutch problems?
Crankcase oil may be fuel-contaminated, perhaps due to an imperfect float valve and/or float mechanism.donthaveakawman wrote: ...used a brush to get the oil inside the filter...That filter really smelled like gas.
Last edit: 20 Nov 2012 22:51 by Patton.
- donthaveakawman
- Visitor
21 Nov 2012 00:54 #559396
by donthaveakawman
May be a combination of the two.
