Hole in piston
- strobel5
13 Jun 2012 13:39 #528841
by strobel5
1978 kz650d(SR)
Replied by strobel5 on topic Hole in piston fml
thanks for the info, i guess thats one more thing I will be tearing into, the only reason I suspected the gas thing is because I smell the gas when I drained the oil.
1978 kz650d(SR)
- strobel5
13 Jun 2012 15:38 #528867
by strobel5
1978 kz650d(SR)
So I checked the jets real quick today, main: 110, pilot jet 1: 20, pilot jet 2: 50. Does that sound right for the bike with a 4-1 baffled exhaust and pods?
1978 kz650d(SR)
- strobel5
- gd4now
- Denco where did you go?
- Thank you received: 440
24 Jun 2012 02:29 #531376
by gd4now
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Replied by gd4now on topic Hole in piston fml
A 78 650 SR with carbs that has the additional 50 jet over the pilot jet. Sounds like a D1A that came with vm22ss carbs. Stock the vm22ss came with a 90 main, and a 15 pilot. I would think a 110 main and 20 pilot may be a little too large for the 22s.
On the other hand if the carbs are the vm24ss that came on the D1, but it is my understanding did not have the additional 50 jet over the pilot, came with 102.5 main and a 15 pilot and a 110 main would be a good starting point for pods and exhaust changes. Most of the time a 17.5 pilot is also required with pods and pipes. But a 20 may be too big.
A couple of ways to tell just which carbs you have are as follows:
There is an ID stamped on the flange just below the choke handle that will ID the carbs. If you post what is there I should be able to tell you what you have.
You can also look into the intake bell (pull a pod and look) and the 22s have an additional port at about 10 o'clock that the 24s do not have. See pics below - first shows where to look for carb ID stamp. The second is of a set of 24s on top and 22s on bottom - note the additional port on the 22s.
1977 KZ650 B1
- strobel5
25 Jun 2012 12:33 #531616
by strobel5
1978 kz650d(SR)
I looked and it has the extra port and the side it has "n8" and what looks to be "11".
1978 kz650d(SR)
- strobel5
25 Jun 2012 12:41 #531617
by strobel5
1978 kz650d(SR)
Update, so I got the engine out and took off the oil sump and there is metal and what looks to be silicone everywhere. Doesnt look like I can just flush out the engine.
Attachment IMG_1135.JPG not found
Attachment IMG_1146.JPG not found
1978 kz650d(SR)
- strobel5
25 Jun 2012 12:43 #531618
by strobel5
1978 kz650d(SR)
Attachment IMG_1136.JPG not found
Attachment IMG_1138.JPG not found
Attachment IMG_1139.JPG not found
1978 kz650d(SR)
