how to adjust my slotted cam sprockets??
- boose
Attachment IMG_0527.JPG not found
- LarryC
Did you have the head and block shaved to get the compression ratio back up because you used KZ pistons with a J Head?
Larry C.
- Motor Head
- Thank you received: 391
- Nebr_Rex
- Thank you received: 300
And use the link posted above to help you thru the cam degreeing process.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- boose
- boose
thanks for the link.. I will research and start wrenching after work today...Nebr_Rex wrote: 'Decking' will retard can timing from what it was before.
- boose
- LarryC
boose wrote: Correct... Old head needed milled bad, Long story short my good friend raced Kz drag. Had a few heads laying around and we decided it was time to upgrade. The head u now have came off of a nitro bike which has lower comp. so yes in order to get it back up we took 15 thousand off or so, and figure shave the cyl down to get good seal am up comp a Lil as well. Cyl was 30 from hole we took off 17 thousand
I thought so. While that works, it's not the best route. Using the correct pistons is always the better choice. Decking the head and block brings valves into closer proximity to the pistons & the valve angle on that head will not match the valve angle of the valve pockets on the pistons. Close but not exact.
I hope you don't have Andrews 3x cams. Those have a ton of overlap lift. That is important especially considering you don't have experience in degreeing the cams and the crucial clearances that need to be adhered to.
My advice to you is to run no tighter than 108 centers. Good luck Pay close attention to what you're doing. Hope it all goes well....
Larry C.
- boose
- mark1122
- Keep twisting it
- Thank you received: 109
if u have wiesco pistons for a kz, the pockets r cut for a kz valve and head. now u have a j head with bigger valves, and milled some off. so u need to be careful that the pistons dont get to close to the valves and the valves dont get to close to each other. talk to your bud that gave u the head. he will be able to explain exactly what to measure, and why. as the lobe centers #'s get smaller, the valves come closer together. since u r mismatching parts , its best to measure everything properly, rather than risk using numbers u hear may work.
it would be interesting to know what the compresion is now. u may need small lc's to gain compresion with that head, but maynot be able to use them since it has been milled.
are u running 1075cc's ?
learning is part of the fun.
Good luck and have fun.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- LarryC
Here's the deal with what you have going on. 2x on stock sprockets with a fresh cam chain would be on 110 centers [approximately]. Andrews calls for a 106 on that grind. 108 is half way. Moving a cam 2 degrees isn't anything you're going to notice a big difference with.
If it's idling rough and if you have an old cam chain and old idlers in the motor, your centers may be above 110. I've seen them as high as 118 with a stretched out cam chain before. Can't say what you have BUT if the bike idles poorly and the carbs are setup correctly, then very late cam timing could be the culprit.
If your ignition system as a rev limiter, set it at 8500.
Larry C.
- boose
