80 kz750 4 cyl power stalls on full throttle
  • Yotaracer4life
  • Yotaracer4life's Avatar Topic Author
07 Apr 2012 19:37
#514587
My kz750 suddenly had a loss of power when i was riding it, and now it backfires and dogs down on full throttle. if you turn the throttle slowly it revs up without a problem, any ideas as to where I should start? Im pretty sure that its not the carbs because they were just cleaned.
Re: 80 kz750 4 cyl power stalls on full throttle
07 Apr 2012 19:42
#514588
What are you using for air filtration?
  • Yotaracer4life
07 Apr 2012 19:46
#514590
k&n pods, has a kerker pipe and mikuni vm29 smoothbore carbs.
07 Apr 2012 20:16
#514595
I'm positive others with solid hands-on experience will chime in with good advice, but 29mm smoothbores & pods sounds like a lot of carb for a stock KZ750 unless the carbs are tuned down a bit. Maybe someone can offer suggestions on appropriate jetting. Ed
  • Yotaracer4life
07 Apr 2012 20:19
#514597
Im pretty sure it has nothing to do with jetting since the bike ran great before the other night I would full throttle it and it would get up and go,
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
07 Apr 2012 20:37
#514599
How long ago were the carbs cleaned? Could one of the jets have worked themselves lose? Are there air or vacuum leaks on the carb holders?
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
07 Apr 2012 20:48
#514601
I always wonder about fuel, sitting and getting old and water ladden when fuel problems happen this time of year after sitting for a long time. Take the tank off and drain it and start fresh if their is any doubt. use the old fuel in a cheap lawnmower if you must.
  • Yotaracer4life
07 Apr 2012 20:51
#514603
the carbs were cleaned about a week ago, and there are no cracks or leaks in the carb boots everything is secured tightly. and on the gas its my third tank in the last week
07 Apr 2012 23:55
#514634
Perhaps there's an issue with the ignition advancer being slow to reach open position.
Might need lube, or clean and lube.
Good Fortune! :)
  • Yotaracer4life
08 Apr 2012 18:07
#514740
the ignition advancer is clean and moves freely, I discovered that it runs better with the choke on and if I turn the air mixture screws in all the way it runs better with the choke off. but still doesnt have as much power as it should.
08 Apr 2012 18:35
#514743
Have the float bowl fuel levels been measured using the clear tube method?
Good Fortune! :)
  • steell
  • steell's Avatar
08 Apr 2012 22:40
#514774
Take off the petcock and clean the screens that are on top of the petcock and inside the tank.
