Do I need new pistons?
- beewerks
'81 KZ750 E2 project bike
'05 Yamaha TW200 commuter gas sipper
'08 Yamaha Zuma 50cc scoot
- jeffecor
- Thank you received: 1
1980 Kawasaki 750 h1 ltd
- apbling
- Thank you received: 12
One possibility would be to spring for the Wiseco big bore kit, which would take you to an 810 cc, but then you would have to tinker with the carbs, and the kit itself isn't cheap either...
- jeffecor
- apbling
What do the pistons and jugs look like on the used motor? Maybe just hone them and re-ring, install on your installed one and do that?
I know that when I blew a piston on my 550, I bought a new piston (it was $50 through Z1) and just honed that cylinder and put new rings in it. Cut new valve seats too. Money was really tight and I didn't want to spend anything on the repair. It runs ok, but I'm not hot rodd'ing around either. Problem is my compression on that cylinder is lower than the others...
- beewerks
- JEFFG1
- Thank you received: 16
1976 KZ 900 PRO STREET 1977 kz1000 dragbike project
- bountyhunter
- Thank you received: 337
- DoubleDub
- Visitor
bountyhunter wrote: When I tore down my 750 twin with 75k miles on it, I did not see any cylinder wall scoring like that. I don't think that is normal wear.
+1 - cheapest route will be a good/used block, piston, and ring set from fleabay/classifieds.
- zed1015
- Thank you received: 1599
Looks like it's been run low of,or in very contaminated oil and picked or has overheated and been close to partial seziure.
You could give it a light hone and re-ring but the piston/bore clearances will be shot and most likely won't last long till its burning oil and down on compression.
Oversize pistons (either new or good used)with a re-bore and new rings is the only way to go if you don't want to take it apart again in 500 miles time.
- beewerks
- zukdave
- Thank you received: 229
junk you have (and it is junk ) buy the Wisco 810 kit.
Simple bore job and put it back together
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
